Question about Compaq Computers & Internet
Can not boot from cd error code 05 - Compaq Computers & Internet
This will help you
Posted on May 13, 2014
Iomega Screen Play HD showing fatal error 05 -
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Sep 25, 2009 | Iomega ScreenPlay
Dvd boot error problem....
That error probably came from the CD ,doing a search on "bootscriptor" returns several links regarding bootable CDs.
Jul 15, 2009 | E-Machines T5082 PC Desktop
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
Cd read e-05
Well E-05 error code on Kenwoods is "the cd is upside down" So either the disc is upside down or there is a problem and the Kenwood unit thinks it is upside down.
Mar 05, 2009 | Kenwood KDC-MP332 CD Player
T23 BIOS error code #05
are you getting a date & time error ?. you could always try just resetting the bios.... remove the bios battery AND the battery itself for about five minutes or so. install it all again and boot up.
Robert
Aug 27, 2008 | IBM ThinkPad T23 Notebook
Blue screen error code 0x00000ED
Solution:
use the following steps below:
Start your computer with the Windows startup disks, or
with the Windows CD-ROM if your computer can start from
the CD-ROM drive.
When the Welcome to Setup screen appears, press R to
select the repair option.
If you have a dual-boot or multiple-boot computer, select
the Windows installation that you want to access from the
Recovery Console.
Type the administrator password when you are prompted to
do so.
If no administrator password exists, press ENTER.
At the command prompt, on the drive where Windows is
installed, type chkdsk /f/r, and then press ENTER.
At the command prompt, type exit, and then press ENTER to
restart your computer
But if you dont have the operating system cd, you will have to remove the hard drive connect it to another machine and perform the steps above and then connect it back and it should work.
Regards,
Yateesh Varma.
Jun 14, 2008 | Dell Inspiron 2200 PC Notebook
Error Code E-05?
Error code )% i think means no focus, you could try cleaning the laser, but otherwise its a replacement laser :(
Regards
Mark
Jan 18, 2008 | Kenwood KDC-MP4032 CD Player
Error code - 05 shows on the screen
I have the same Kenwood unit and mine worked great for over 2 years.... I now get the same 05 error code whenever i insert any cds.... I havent yet been able to find anything about this on the net... I am about to take the cd player in for the extended warranty I purchased with it.... It is by far the best cd player that I have ever owned...............
Dec 01, 2007 | Kenwood Excelon XXV-01D CD Player
Kenwood kdc-w6527. ERROR 05
clean the cd lense with a cd cleaner, had the same thing and it works perfect now
Oct 28, 2007 | Car Audio & Video
Computers & Internet Logo
13 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
