Question about Dell Computers & Internet
FLASH LIGHT & FRONT CAMERA INSSTOLING PROCES - Dell Computers & Internet
    Top Expert:
  • Dell Master
  • 22,688 Answers
Please explain your problem.
Posted on May 20, 2014
Panasonic dmc-fz18 camera.The Flash is always used, even if the flash cover is closed. I can see the flash light escape from inside the camera and hear a fuzzy click. Is it broken or is it a setting?
I have a lumix camera, more then likely it has gotten wet or it took a dive, here is what I would try, mind you! I'm taking a shot in the dark & this is a total "hail merry pass" first you need to get all the door type panels open, anything that flips up or open, remove the battery & memory card, buy some canned air for electronics & give it a good shot! do not use the compressor at the local gas station! particulate matter at high speeds is not good for sensitive consumer electronics, "like a photo device" figure a way prop & tip the device so that any condensation can rise & escape from the top, maybe it's your memory card slot? Let your common sence guide you, now your going to get a small area heater, turn it on HIGH HEAT & hold your hand in front. judge the distance so that it's hot, but you can still hold your hand there, without having to pull away.. I think you see were I'm going with this, My friend had a very pricey video production device, he had on loan, & it got just a tiny spray from the wake of a boat & it went in the dead zone. we though it was kaput'z! lucky we were in Arizona & did that trick, except we propped the device in the car in the garage, 12 hours latter, we turned it on & worked perfect! Best Wishes! I hope this helps? P.S. If that don't work & you want to go for broke "how brave are you? see that Lil Philips screw right by the flash?" it's 5% talent & 95% common since...
Feb 19, 2015 | Panasonic Lumix DMC-FZ18 Digital Camera
I have bought canon D40. Problem "ERR 01 Communication between Camera & Lens". I bought the camera in 2009 jan. Can take pic at night with flash but day time i cant. Please help. Lens is super clean.
Get the camera sensor, the mirror and the lens attachment junction with the camera checked. And if you use the camera in auto mode, and there's ambient light, the camera wont fire the flash, coz of its auto light detecting sensor.
Aug 06, 2010 | Cameras
I have had my canon 870is for about 1 1/2 yrs & love it-I have never had any problems until today-the battery flashed red(dead) & I removed it & charged it...Well, now since I put it back in...
Depending on how long your camera has been put away for, and in what conditions it could be either with the camera or the battery itself.
If the battery is older it won't hold the charge, so even charging it and immediately placing in the camera it won't have enough energy to power it on and stay on.
You can try to purchase a new battery for the camera, make sure it is the manufacturer indicated battery. Often people try other batteries and they don't work. it does make a difference.
This company is very reliable http://www.teleplancamerarepair.com/Canon_Powershot_SD870_IS
and they also clean the camera as part of their repair services.
Make sure you tell them what is going for it could be something with the built in flash, or a camera sensor.
Try the battery first.
Jul 13, 2010 | Canon PowerShot SD870 IS Digital Camera
How can I turn down the power on the FL50 to get more flashes. Can you turn down the power on the camera E510 with hte FL50 attatched?
the user manual is here http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/accessories/man_fl50_e.pdf
Have a look at page 46 TTL Auto mode - you can adjust the variable between power setting - + or - 3 stops Page 48 gives full details on adjusting this setting
Light intensity adjustment
  • The flash light intensity can be adjusted between +3 and –3.
  • The light intensity adjustment must be set to ON in the custom setup operation (page 61). • The indicator appears in the control panel.
  1. Turn dial B to select a light intensity adjustment value in the following steps. (This selection is also possible with dial A.)
  • 0 → +0.3 → +0.7→ +1.0 ... +3.0
  • 0 → –0.3 → –0.7→ –1.0 ... –3.0
  1. The display shows the light intensity adjustment value except when the value is 0, in which case the display does not show the light control range.
  2. If the camera’s flash adjustment mode is selected, the actual flash light intensity will be the total of the light intensity adjustment value set on the FL-50 and that set on the camera. The light intensity adjustment value displayed is that of the FL-50 only.
Apr 11, 2010 | Olympus FL-50 TTL Flash
Manual light & exposure settings
if you are using flash lights on the art work, please follow the following steps
  1. turn off your flash in cam since it bypasses the external flash and makes the picture look different.
  2. turn your light settings to either automatic or "flash light or arc light".but do not set them to incandescent light!!!
  3. turn your macro to on status if you are going to take a close up shots, but please note that close up shots work great in natural sunlight than at flash lights...
Sep 13, 2009 | Fuji FinePix S2000hd Digital Camera
Same issue!
CENTER POINT &SIDE OF THE FLASH FOR OPEN FIRE
Jul 12, 2009 | Canon Speedlite 430EX TTL Flash
D70 Will not flash with built in flash
try to replace the battery, maybe it's too weak
Aug 20, 2008 | Nikon D70s Digital Camera
How do you turn on the light on the front?
This camera does not have a light what is on the front of the camera is a flash, not a light. It is available when you are in photo mode but not in video mode.
Sorry!
May 04, 2008 | Vivitar DVR 530 Flash Media Camcorder
Kodak Easyshare Z760 orange light flashing
The flash does not charge separate from the rest of the camera. Try cleaning the flash sensor on the front of the camera or the flash led may be bad.
Secondly, this light functions as a flash sensor which is trying to tell you that you need to use a flash although you may have the flash manually turned off. looks like a bolt of lightning with a circle/slash through it.
May 09, 2007 | Kodak EasyShare Z760 Digital Camera
Computers & Internet Logo
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
