Question about GE Refrigerators
Frostguard We have a side by side GE freezer. My wife left the door ajar overnight and now everything is snowy in the freezer. It was running and then I closed the door and the fan stopped but it did not appear the temperature was dropping. How long until the freezer starts to cool again?
  • 656 Answers
It should get plenty cold in one hour.
Posted on May 13, 2014
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
  • 74 Answers
SOURCE: GE GSS22JEPA WW
This could be a sensor issue , that is what i would be changing in the first instance. The sensor connects into the same connector the vent door connects into.
Posted on Sep 02, 2008
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
lenwest
  • 150 Answers
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
  • 153 Answers
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
Posted on Jul 21, 2009
Water under fridge sometimes ice
Defrost unit and work everything loose. Wipe off all water and let it sit over night. Plug in next morning and allow 24 hours for temps to be right.
Sep 09, 2017 | Whirlpool GX5FHTXVA Bottom Freezer French...
Freezer door pops open about 1/8" when you shut refrig door
this is very normal this means that you have an extremly good seal .. causing air to push threw duct work when closing door .... try changing the levelnes of refrigerator so when door does pop open it falls back closed meaning tilt fridge front higher than back of fridge
Feb 01, 2011 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
FREEZER AND REFRIGERATOR NO LONGER COOLING (GE MODEL GSS25XSRDSS)
Not enough info. If the unit is totally dead then I would suspect the main board (in the rear under a panel) if the fans are running I would suspect the compressor is not running.
Oct 16, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
I have a ge refrigerator gss25xsr. The refrigerator is freezing. I've lowered the temp to 1 however not change. Any suggestions
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
We have a side by side and the refrigerator side is freezing everything. we have the settings on 2 and D
Nov 16, 2009 | GE GSS20DBT 19.9 Cu. Ft. Side-By-Side...
The freezer door was ajar overnight and now the icemaker is leaking water
chances are alot of the ice melted overnight. remove all of the ice cubes, dry everything out and then wait a full 24 hours for the icemaker to produce ice cubes.
Aug 28, 2009 | Kenmore 21.7 cu. ft. Side-by-Side...
Freezer is cold but not fridge
there is a little trap door at rear upper corner of frig/freezer. (side by side type) Not sure where it is on others. Opens to cool refrig side closes when right temp is reached, Either link to operator is frozen or broke. Should be fixed (replaced) by repairman, easy, fast not too expensive.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by side runs constantly.
The timer that controls the defrost cycle/function, may have failed and there may be no defrosting occurring. If icing of the coils due to the missing defrost cycle, there may not be enugh circulation left to keep the thermostat happy.
Try defrosting it manually (I know, it's a pain - aren't we spoiled?) and see if the compressor then cycles for a few days before it starts running continuously again.
And for Dr. Fred, the above suggestion about trying manually defrosting applies to your problem too.
The exposure to overnight moisture (ice accumulation) may have interfered with the automatic cycle.
Aug 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
