Question about Metrologic Instruments 9520 Voyager
MS9520 only shows yellow - wont do anything
I cannot figure out how to set this up so I can scan labels for my amazon account.
I have a hard time paying my Amazon prime acct what is the correct website
www.amazon.com is the correct site. After you sign into your account, look for the tab at the top of your screen labeled "Account and Lists".
Then find the link titled "Your Prime Membership"
You should be able to set up your payment method from there.
Mar 27, 2017 | Amazon Computers & Internet
Friend of mine got me Fire tablet and trying to register it and wont except info,do I have to pay for Amazon Prime to use it?
No you don't need Prime, but you have to create an account before you register.
To buy content and deliver it to your device, you'll need to connect to a wireless network and register your Fire tablet to an Amazon account. Registering also allows you to transfer purchases between devices and Kindle reading apps. To learn more about connecting to a wireless network, go to Connect Wirelessly.
  1. From Home, swipe down from the top of the screen and then tap Settings.
  2. Tap My Account.
  3. Tap Register.
    • If you already have an Amazon account: Enter your Amazon account information, and then tap Register.
    • If you do not have an Amazon account: Tap Create Account, and then follow the instructions to set up a new account.
Register Your Fire Tablet
Jun 12, 2016 | Amazon Kindle Fire HD 7 inch Tablet with...
HOW TO UNSUBSCRIBE FROM FILEDROPPER?
Login to your account.
Go to account settings.
Go to subscriptions
Remove subscriptions as per your requirement.
OR
When next time you got mail from filedropper.com;on the below of the mail is unsubscribe link.click on that link,enter your email and you will be unsubscribed.
Aug 10, 2015 | Computers & Internet
How i can configurate ms9520 by rs232 which command can i use
Scanners are programmed by printing the barcode & then scanning with them. For this one, go to https://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf
print it & scan the relevant barcode.
Dec 16, 2014 | Microsoft Metrologic MS9520 Voyager...
Metrologic ms9520 not scanning UPC's
Hello.
The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code.
You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.
http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40
Hope this helps!
Dec 01, 2011 | Metrologic Instruments Voyager MS9520...
I want scan barcode 39. Hou can i program mine ms9520 voyager scanner. Thank you
http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf
That is a link to the PDF help file for the MS9520. It has barcodes inside that you scan with your scanner to enable/disable certain features. It looks like you should be able to enable Code 39 barcodes by scanning the barcode found on page 2-2 (actually on page 10).
May 26, 2011 | Honeywell MS9520
Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
I have not instruction for default settig where are barcode for default setting
Check metroselect single line configuration guide page no. 2
1) Scan Enter/Exit configuration mode it gives 3 beeps
2)Scan recall defaults it gives single beep
3)Scan Enter /exit configuration mode it gives 3 beeps
Now scanner is set to default setting
Sep 16, 2009 | Microsoft Metrologic MS9520 Voyager...
Metrologic MS9520
You can reset back to original setting using your manual. If you are using cash register you need to look for the right settings in order the scanner will working.
Rate me SOLVED
Nov 21, 2007 | Metrologic Instruments 9520 Voyager
Metrologic Instruments 9520 Voyager Logo
48 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
