Question about Frigidaire Dryers
Dryer motor is bad - Frigidaire Dryers
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
They can't be fixed and have to be replaced.
Posted on May 19, 2014
How can i test my dryer to find out if the motor is bad
If the drum goes around, your motor is working.
If the drum doesn't go around, the belt could be off or broken, or the motor could be bad.
Try to listen for the motor starting up as you turn the dryer on. If it sounds like it is running (an initial 'bump' followed by a quiet hum), chances are it is a belt problem.
If you can't hear the motor running, or it is a loud buzz, or there is the smell of burning insulation or smoke, chances are your motor is bad.
It is also possible that the selector switch that controls everything is not turning the motor on (bad selector) or the overheat safety switch is malfunctioning, but these need to be tested by taking the dryer apart.
Nov 18, 2014 | Crosley CDE6000 Electric Dryer
Dryer hummes when you turn it on but does not rotate
This don't sound good most likely the motor is bad . OK first unplug the dryer take the belt off the motor now plug the dryer back in hit the start switch does the motor turn NOW??? If not its the motor. IF the motor does turn??? could be a weak motor OR Bad bearing in the Back of the tub.
Rotate the TUB by Hand UNPLUG THE DRYER FIRST. IF the tub Rotate freely I would say you
Have a bad Motor But if the tub is very hard to turn now your looking at a bad Bearing
GOOD LUCK HOPE THIS HELPS
Nov 21, 2010 | LG DLE5977 Electric Dryer
Motor humms bt will not turn, unless you help it
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 31, 2010 | Estate EED4300VQ Electric Dryer
Gas dryer 12690. When stopping dryer in the
When the dryer stops and you try to restart it do you hear a buzzing sound? If you do then you have a overheated drum motor. Full of lint or bad motor bearings. If bad motor bearings only solution is to replace the motor.
Mar 29, 2010 | Kenmore Dryers
Motor runs slow with belt off then will speed up frigidaire dryer
bad motor / holding button will burn it out. ths keeps it on start winding . try blowing the motor out ( delint motor and dryer . ) it will run cooler . motor sounds like it already bad and needs replacement. mm
Dec 03, 2009 | Frigidaire FER231A Electric Dryer
Dryer cuts out
Either a bad motor or power problem . If dryer has been there for a while and worked fine , then motor is bad . If dryer has recently gotten there , check the cord to make sure it's connected properly , and the wall receptical has 240 volts where it should be ( both 1/2 " straight terminals ) The " L " is ground .
Aug 20, 2009 | Kenmore 659 Electric Dryer
Indesit washer dryer, washer is fine, but dryer does not heat up
If you don't hear the fan running then the fan motor has gone bad. If the fan motor is bad then most likely your element has burned out. If you hear the fan motor than probably your element has gone bad..
Jul 29, 2009 | Splendide 2100 Vented Washer-Dryer
Dryer On Switch
If you're really lucky it may be a broken or burnt off wire at the motor, but more likely you have a bad motor. When you push the start button you are energizing the start winding on the motor, but if there is no circuit through the run winding the motor will not continue to run when you release the button. Could be a bad run winding or the centrifugal switch is not resetting when the motor stops. Either way you are most likely looking at a new motor (expensive and usually a pain to install) or replacing the dryer. Sorry for the bad news. (remember good advice = fixya rating)
Sep 03, 2008 | Dryers
Dryer runs only when "Start" button is being pushed
--Bad motor run windings
--bad motor switch
These are two possibilities.How old is the dryer. may not be worth it. get the model# from the dryer & price a motor. (new motor cures both of these possibilities)
Oct 29, 2007 | Dryers
Dryer problem at startup
--bad motor switch
Oct 17, 2007 | Hotpoint NWXR473EV Dryer
Dryers Logo
19 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
