Question about Refrigerators
Why is the refrigerator not cold, but the freezer is?
Samsung model RF26AEBP
docjohn174
  • 943 Answers
SOURCE: Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Posted on Sep 25, 2008
rpbuice
  • 161 Answers
SOURCE: Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Posted on Jan 12, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Refrigerator is somewhat cold as is the freezer
Your refrigerator has a defrost timer located near the floor and behind the kick plate. Remove the kick plate grill and turn the timer slowly clockwise until refrigerator compressor stops running. Leave it there for about 30 minutes or until refrigerator restarts. During this time the refrigerator should be in the defrost cycle. Open the freezer and you will possibly hear a crackling noise or the noise of water sizzling as it drips from the evaporator to the defrost heater. If your refrigerator does not restart after this time then turn the timer again slowly until the compressor restarts. If you do this then the timer will need replaced If no defrost takes place during this time then we need to move to the rear of the freezer and unplug the refrigerator and do some test on the defrost heater. Let me know how this worked out for you. The part number for your defrost timer is 10530703
Thanks, Sea Breeze
Posted on Jun 24, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag model # mbf2254hew bottom freezer refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
heatman101
  • 43501 Answers
SOURCE: GE Hotpoint Top-Freezer model - freezer works but
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 01, 2010
I have a 2013 Samsung frig model rf28hfedbww/aa. The top part is not cooling The freezer is ok
Freezer supplies cold air for the fridge section.. Check fridge gasket for tight seal, operating freezer fan along with proper operation of damper mechanism which directs flow of cold air into the refrigerator.
Sep 04, 2017 | Samsung Refrigerators
Samsung model RFG297HDRS manual
then you need a repairman . or a new one
Oct 22, 2015 | Samsung RFG297HDRS 29 Cu Ft Stainless...
Samsung Refrigerator MODEL RF263AEBP/XAA. Freezer is Cold But Refrigerator is Warm
remove back cover in the freezer and check the evaporator fan motor. Also see ice patern. Possible defrost problem
Aug 24, 2014 | Samsung RF265AA Bottom Freezer French Door...
Samsung refrigerator model rs2545sh/xaa. Freezer works good, but refer side does get cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Samsung RS2630SH Side by Side Refrigerator
What temperatore should a samsung fridge be ,the model i have does not seem to be all that cold ,the freezer section is very good. the model is a SR389NME thank you
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | Samsung Refrigerators
I HAVE A SAMSUNG HALF AND HALF FRIDGE FREEZER MODEL NUMBER RL36EBSW THE PROBLEM IS THE FRIDGE WONT GET COLD
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Mar 31, 2011 | Refrigerators
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Temp in the refrige wont stay cold. frezer is fine. model name is rs2545sh
heatman101
Oct 25, 2010 | Samsung Refrigerators
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
