Question about Sangean HDR-1 Radio
ATS - Clock
ATS doesn't work in my area! (or on my set) (Greater Seattle?????)
Also; Set time goes completely hay-wire from time to time.
And again; Clock regularly looses 2-3 minutes per month (when it hasn't gone hay-wire.)
    Problem Solver:
  • 6 Answers
This is a defect in the module. Contact Sangean for service.
Posted on Mar 20, 2008
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Set the clock
go to the screen where you would set the clock. touch the area for hours then below press the number which dictates what hour it is. do the same process for minutes.then you hold the check mark button for a couple of seconds. actually it wouldn't hurt to do that after setting the hour and minute..Also make sure you have all your wiring connected right. Cause the wire that operates the clock has voltage all the time this is what keeps the clock running you may want to check to make sure yours does not shut off with the key, Thank You Hope this helps
Oct 20, 2014 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
I have set the time and day, set program inc. day, off, on. When I switch mode to automatic the timer goes off. Only work in on mode. I have tried this with 3 separate units. What am I doing wrong?
I don't have repair for defective timer.
If following information does not apply to your timer, then add a comment with clear description of timer for possible help.
1) The only complaint about this 6-button timer sold by Woods, GE and Westek is the MODE doesn't work.
The key to this timer is to finish programming, and then press Clock to return to current time, and at this point the timer is in correct mode.
Then do NOT press mode button ever for any reason, except to reset timer.
2) Try resetting timer by pressing Clock Mode and Prog buttons at same time, and then re-program timer.
3) Timer is not heavy-duty. Load rating is 1000watts incandescent, and 1/4 HP.
If load rating is greater, then timer will not operate as expected.
4) If you have problem with timers, try timer on different load and on different outlet.
Test outlet for polarity using circuit analyzer.
Aug 22, 2011 | Woods Outdoor 7 Day Digital Two Outlet...
My clock is constantly blinking and won't go on the right time. I unplugged it and plugged it again, it just keeps blinking.
Check the bckup batteries in the clock first. If they are weak, backup function will not work properly, and the display will blink after a mains power failure.
Auto Clock Set
You do not have to set the clock time as a
built-in automatic time set system is
equipped in this clock powered by 3V (2
X AA batteries, included). All you have to
do is to plug this clock for power and
current time will be shown automatically.
However, the batteries can also be
exhausted and we recommend that you
replace the batteries every 2-3 years
Before You Plug for Power
1. Setting Time Zone
You may slide the TIME ZONE selector at
the back of the unit to Eastern (EST),
Central (CST), Mountain (MST) or Pacific
(PST) (refer to the maps on the right).
2. Daylight Saving
You can slide the DST switch at the back
of the unit to turn on/ off in areas
observing/ not observing such time
WARNING: Please avoid playing with
these buttons after entering the
Clock/Alarm set mode.
Setting Clock
1. Slide the switch /WAKE1/WAKE2/
on the top of the unit to clock position.
2. Press REV or FWD to set the clock
time. The time decrements or increments
will follow by a faster rate when you press
and hold the buttons. The ":" between
hour and minute time flashes when you
are setting the time. AM or PM icon will
also beside the time.
3. Slide the switch /WAKE1/WAKE2/
on the top of the unit to position
when finished.
Aug 12, 2011 | RCA RP5430 Clock Radio
My GE Mod #JBP65GS1AD oven recently started acting up. The bake element had a small glowing area 1/4" long even with the oven turned off. We used it a few times, shutting off the power in between...
The way it can be tested is access the back panel so you can get to the oven control(its the clock asm) find a wire terminal on the clock marked as BA for bake and use a volt meter and see if 120 vac is coming from that terminal when the oven is off. The wire must be removed from that terminal so you not getting back feed and has isolated the test just to that. IF it has 120 vac or actually and voltage higher than about 5 vac when the oven is supposed to off the relay board (aka clock) is bad. UNPLUG OR TURN OFF BREAKER TILL WIRE IS OFF OF BA AND READY TO TEST then restore power make sure its marked as BA their is another marked BR thats for the broil element.
Good luck, i hope this helps
Aug 01, 2011 | GE Ovens
How to set
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner
Mar 15, 2011 | Seth Thomas Radio-Controlled Howard Wall...
ADV-3800, how do I set the clock
Press VCR button to change into VCR Mode and follow the procedures below.
1 Press the SETUP button on the remote control.
2 Press the ENTER button, while highlighting CLOCK SET.
3 Set the current date and time with button or NUMBER button.
For DATE SET, follow the order of Month/Day/ Year ; for TIME SET, follow the order of Hour/Minute in CLOCK SET screen.
4 Press SETUP button after completed.
You can find your complete manual HERE.
Click DOWNLOAD THE DOCUMENT, and then in area 2 enter the verification code, and click download now.
Mar 01, 2011 | Apex Digital ADV3800 DVD Player/VCR
How do I set the clock on a 1998 chevrolet cavalier? The book says to press 'set' but I don't have such a thing on my panel.
Hello. try this and see if this works
Use the following procedure in order to set the clock display:
  1. Press and hold the HR button until the correct hour appears.
  2. Press and hold the MIN button until the correct minute appears.
  3. There will be a 2 second delay before the clock goes into the time-set mode.
Oct 03, 2009 | 1998 Chevrolet Cavalier
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Changing the time
you can go to to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
Jan 25, 2009 | Oregon Scientific FM Weather Projection...
Sangean HDR-1 Radio Logo
186 people viewed this question
Top Sangean Audio Players & Recorders Experts
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
