Question about Bose AV3-2-1II HOME THEATER MEDIA CENTER
Output defect Service Manual
    Top Expert:
  • Bose Master
  • 75,178 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Posted on May 13, 2014
How to replace roland xp 50 keys And also repair outputs
Disassembly the unit.
Your question is less detailed. If the keys is broken,replace with new.
If you mean "How to",then you need the service manual.
Outputs problem,usually causes by output IC (or input IC) is defects.
It also can cause by AD/DA IC is error.
Mar 15, 2015 | Roland Music
Service error 5100
Straight from the Kyocera service manual.
Main charger high voltage error. Five pages have been printed with the main charger output short-circuited.
Causes: Drum unit installed incorrectly. Engine PWB installed incorrectly. Defective engine PWB.
Solution from service manual:
Verify harness is not pinched in the drum unit.
Verify harness is not pinched in the engine PWB.
Replace the engine PWB.
If you have tried to repair the printer yourself, just go over the reassembly procedure, you might have pinched a wire or one of the connectors might be bent or not in properly.
Regards
Jul 22, 2014 | Kyocera Fs-3920dn Laser Printer
How do I test the power pack on a 1996 25 hp. 3cly. Evinrude?
There is no test for the power pack. There are tests for the ignition or kill switch, the charge coils but if there is no output from the power pack the service manual requires the power pack and sensor be replaced one at a time to determine which one is defective. It is possible both are. There are resistance tests for the charge coil, engine harness, ignition/kill switches that are performed with an ohmmeter but output tests must be performed with a peak reading volt meter.
Aug 28, 2013 | Boating
The power is ok but there is over all vertical lines, the heatsink is very hot and there is a defective capacitor
The set need serious service. Download its service manual from net and follow. Check the video output section, and chroma processigng section.
May 08, 2012 | Philips Televison & Video
My samsung mini camcorder scd103 screen and veiw finder is white. i can't record picture but i can record sound.
Hi,this sounds as if the LCD monitor is defect and will be in need of replacement.To confirm LCD defect,insure that problem is with display, by verifying video output to TV or PC.If video is alright through a/v outputs to TV,than LCD is defect.However,if TV output is also white,than problem lies on main camera PC board.Whichever the case I do think that warranty repair should apply on this model and suggest to contact mfg factory service.
Note - In few cases i have seen that even corrupted firmware could cause the same.
Good Luck!!
Thanks!!
Aug 19, 2010 | Samsung SC-D103 Mini DV Digital Camcorder
DAV DZ230 HOME THREATRE SYSTEM
This error message can only be removed when you will replace defective part (most probably bad output IC) in amplifier section of unit.
Defective Part removal requires good solder work, few tools to open / apart unit and de-solder and solder IC, knowledge of electronics etc
As you said, you are not experienced so I would recommend to contact Sony Service for proper fix of this unit. If you need further info, please let me know to assist you.
Below is picture of related service manual.
Good Luck.
Nov 24, 2008 | Audio Players & Recorders
Onkio receiver
The output transistors should be replaced in pairs. Also, It may not be just the output transistors that are defective. If you have no experience with these types of repairs, I would suggest that you bring the unit to a service shop. The outputs will run about $15-$25 per pair.
Dan
Aug 29, 2008 | Onkyo TX-SR601 Receiver
T.V.
chances are its your vertical output ic it resoldered or its defective and needs to be replaced if you would like I can post you a link to get a service manual for your tv with free online tech support
Apr 23, 2008 | Philips 55PW9363 55" Rear Projection...
All functions turn on, but i can listen to music. The output integrated circuit is broken
Hi there OSKY,
I would suggest that you try and obtain the service manual for this system of yours. Usually from the manufacturer or an alternative source.
The model number and the manufacturer are listed on the rear panel of the sound system.
Once you get the service manual it will list the correct part number and the type of IC installed in that particular model..
You havent listed the model or manufacturer for me to search my own service manuals , so I cant provide you with the IC part number...without a good description of it..
Cheers YUBEUT...
Nov 16, 2007 | Panasonic SC-EN7 CD Shelf System
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
Bose AV3-2-1II HOME THEATER MEDIA CENTER Logo
63 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
