Philips soundbar the power went out suddenly have no idea hat happened
    New Friend:
  • 113 Answers
You may have blown out your speakers. Which can happen if your sound volume is too loud. Try looking at your connections, maybe a loose wire somewhere.
Posted on May 13, 2014
No sound via philips soundbar hts8100 with philips 52pfl7403d tv
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Sep 09, 2016 | Philips Televison & Video
My Philips Htl2160 soundbar just quit working after I tried to upgrade the firmware! It won't light up that it's getting power! I disconnected everything and reconnected, but still nothing! Any ideas?
Updating firmware is dangerous as it configures the part before the software loads. If the firmware update fails or the power cuts it renders the item inoperable as you have found. You will have contact Phillips for either a replacement unit or for a zipped firmware file to reload again.
Nov 22, 2015 | Philips HTL2160/12 Soundbar 60 Watts
Connect Sound Bar to TV (flatscreen - Proscan)
How about fiber optic cable or composite cables. I usually recommemd that people do either of these.
Jun 04, 2014 | Proscan Televison & Video
Proscan how to
I have a Proscan Flat Screen TV Model PLEDV2845A. I want to connect my Philips HTL2101A Sound Bar.
I have intially connected both via Coax cable as the soundbar does NOT have HDMI port. I then went into the setup on the TV to Sound, set sound to PCM
Initially it worked fine. 2nd day it will not won't work. Per instructions from Philips I have upgraded the firmware on the SoundBar.
Any ideas
Jan 06, 2014 | Proscan Televison & Video
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
After the soundbar has been running for awhile the sound disappears. At that point I have to turn it off for a few minutes and turn it back on. After another period the sound will disappear again. This...
Hello, that sounds a power supply problem, maybe a bad capacitor or the amplifier chip is overheating, basically the board inside needs be checked and fixed.
Thanks
Nov 22, 2013 | Philips HTS8100 AmbiSound Soundbar DVD...
I was watching my team in the first half of their fisrt game of the NCAA and it suddenly went black and it wouldn't turn on after that. It was working perfectly fine before it happened. Please h
You have indicated this is a 50PF9630A Philips which is a Plasma set.
If you have not done so unplug and then replug the set--if still same issue the set has a problem.
Someone would have to open and examine for power supply problem and then begin sub of boards (buy and replace) to see which board or boards are bad.
Mar 15, 2012 | Philips 50PF9630A 50 in. Plasma Television
PHILIPS 50 Inch HD DLP Projection TV the picture went out suddenly and there is not sound but a loud humming-buzzing coming from the set...any ideas on what could be wrong or if it can be fixed?
It's the optical block (color wheel) and the same thing happenned to our Philips 50" DLP. From what I've read, it's not worth the trouble & $$ to fix. Dig a hole!
Oct 16, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Reset my soundbar
Amp is probable going into protection mode. Disconnected all speaker and av wires (only power) and check if it switches on. Try to plugged it in also at another wallsocket. Presume PSU damaged by surge
Aug 12, 2009 | Philips SoundBar DVD Home Theater with...
 Grubhead
Grubhead
