Question about Tools & Hardware - Others
What do I do if my router has 33mm guide bush but jig a want to use says I need a 30mm guide bush?
SIP 01478 Router 1500w Variable Speed
  • Joel Friedenberg May 13, 2014
    A few models require the plastic sole plate to be removed from the router: to install a guide bush, to mount a plate to accept bushes, or to set the bush in a moulded socket in the base. The two Tritons are of this type, as are the Chinese-made SIP and JCB models. It seems that the base has to be removed. I inclued a pic .
  • allison_carr May 13, 2014
    Hi Joel. Thanks again but think it is a bit too much for me so have decided to return the SIP and buy a macallister as it is the same price but already has the 30mm bush. Regards. Allison
    Genius:
  • 1,114 Answers
Look up 30mm router guide bushings on the web. Do a search. You'll find several sites that carry a 30 mm bushing.
Posted on May 13, 2014
Testimonial: "Hi Joel. Thanks for the reply but I have already done this and found lots of them but also lots of reviews from other users saying they can't find any that will actually fit the SIP"
3 Suggested Answers
  • 5 Answers
SOURCE: can i use 30mm guide bush to cut worktop with a
Yes you can. You probably would want to do some test cuts in the wood that you are using.
If your worktop is hardwood then each pass will have to be maximum 1/8". It will take many passes depending on the thickness of the worktop. This is assuming that a carbide bit is being used. The smaller the diameter of the bit the less resistance. Also using a 1/4" shank on the bit and the HP of the router determines how fast the router will cut.
Posted on Sep 07, 2009
JakeSully
SOURCE: Got a worx router,model wx15rt cannot find a 30mm guide bush
If you can't fabricate your own. Get a dedicated or universal sub base for the WX 15RT Router, this allows attachment of trend and other bush guides
Posted on Jan 29, 2010
M phone wont call out.. it has a constant dial tone ..can you help me?
Might be a firewall setting in your router. See if you can change the SIP ALG setting. If it is off, you need to turn it on.
Here is a site that will help you identify the SIP ALG in your router:
http://www.nextiva.com/support/how-do-i-identify-sip-alg.html.
May 31, 2015 | magicJack Plus
Freud ft2000 switch
You can find a part diagram and parts list on-line. Just enter the model #. The variable speed control module is no longer available. You can bypass the control, and connect the router directly. You will no longer be able to control the speed, or turn off the router. I used a variable 15A control box instead. It will function the same way.
You may want to just replace the router with a new up-to date router, I just purchased a 2 1/2HP Skil router kit tah has a 1/2 chuck, and both a plunger base a flat base, for $100 at a big box store.
Mar 23, 2014 | Freud FT2000E 3 Router
Dw621 pulsing speed problem
Try to start it at various speeds. Use contact cleaner on the switch, and the variable speed control resistor.
Mar 02, 2014 | Dewalt DW621 2 HP Evs Plunge Router W/...
Variable speed control board for my router does not work. The board part has a number 1303
see if you can locate the manufacturer's website . even thru canadian tire .I could not find anything here
Oct 16, 2017 | Garden
Why do I have one way sip audio on my belkinF5D7234 router
That router has compatibility issues with some VOIP modems which I am guessing you are attempting to use and that result in one-way SIP.
You may need to check if the router is compatible with your modem
Jan 27, 2013 | Belkin Computers & Internet
When the router is at slower speeds, I can stop the motor when pushing wood through a bit. when I back off, the motor starts up again. Is this normal or do I have a problem with the router.
Is it a variable speed? Routers only cut at high speed, wood anyway, if it is variable speed, They must think you will be cutting something soft, I don't know, But they are like a dentist's drill, when they slow down, they don't cut, Keep that thing on high and make some dust, it should not bog down, If it does, check the brushes, if it still does, it has lost it's power and is basically shot. get a new one. Hope this helps.
Feb 27, 2011 | Porter Cable 3 1/4 Hp Bb Router
Adjusting the 5 speed router for different size bits
Go to Dewaltservicenet.com and in the middle of page at bottom it will ask if you are looking for manual, type in your model number and on the next page look at the manual for the type 3 router. Hope this helps
Jan 25, 2009 | Porter Cable 75182 Variable Speed Router...
Variable speed switch FERM ROUTER
the variable switch had 5 connection points on it, i bridged the connection on the 2 outer points with insulated wire,pretty much to see what would happen, this worked,
as this will be a router fitted to a table i will at some point remove the wire and
attach a 5way rotary switch, used for guitar electrics and mount it
into a electrical switch casing,
Oct 10, 2008 | Freud Tools & Hardware - Others
Tools & Hardware - Others Logo
159 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
