Question about Garmin Forerunner 50
How is the chime switched off on the forerunner 50. In train mode i press and hold view/or just press view, this switches chime on but will not switch it off, The chime symbol remains on.Any suggestions
I re-read the manual properly this time. Thanks.
Posted on Jun 25, 2009
How to I take off the hourly alarm off the WR30M of Honhx?
To remove the hourly alarm (or 'chime'), try this :-
Press and hold the RESET button and then press MODE. If you want hourly chime ON - all the days will be displayed, press MODE button again to switch OFF the chime - all the DAYS will disappear.
Hope this helps.
Oct 05, 2016 | The Watches
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
Can i set the f50 to beep after each mile i run?
Yes. When in Train mode, press and hold start/stop to enter the settings mode and press the View button until "Auto" appears to turn on AutoLap, then set the distance to 1.00. your watch will beep at every mile and automatically record each mile split for you. ... its one of my favorite features!
Sep 30, 2009 | Garmin Forerunner 50
The unit does not switch on nor does it show battery charging in progress when attatched to the charger unit
The device may just be locked up and needs to be reset so that it can start up normally. To do a reset on the device, make sure the unit is plugged in to the charging cable/cradle and connected to power. Next press and hold the Mode + Reset buttons at the same time for approximately 10 seconds. After releasing the Mode + Reset buttons, attempt to power the device on normally.
Jun 11, 2009 | Garmin Forerunner 205 Gps Training Watch
I can't turn the chime off my Garmin50
press and hold the view button on time screen. The chime icon will flash, after few seconds it disappear
Apr 10, 2009 | Garmin Forerunner 50
CANNOT PAIR FORERUNNER 50 WITH HRM, FOOT PAD OR PC
maybe you can find something helpfull here:
http://www8.garmin.com/support/userManual.jsp?market=67&subcategory=68&product=010-00679-05
Good luck.
Feb 26, 2009 | Garmin Forerunner 50
Garmin Forerunner 50 Train Display Settings
I was having the same problem and came across your post - I figured out how to change the secondary display.  While in Train mode, with your foot pod activated, hold the View button.  The secondary display will change and say "CAD" or "PACE"...keep doing this until you get to the right display.  Hope this helps!
Jan 15, 2009 | Garmin Forerunner 50
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
Nov 22, 2008 | Timex 1440 Nylon watch
Garmin Forerunner 50 Logo
222 people viewed this question
Top Garmin Watches Experts
Marvin
Marvin
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
