Question about Nexgrill 720-0234 (LP)
Sear burner shooting fflames not glowing - Nexgrill 720-0234 (LP)
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 113 Answers
Try turning down the temperature on your gas grill. Have you tried cleaning the grill with chemicals lately? Grease on the the burners maybe? Just found out that WD-40 is great for cleaning the grill. But you probably have to wait a while to use it again. Wipe excess cleaner off with dry paper towels.
Posted on May 13, 2014
What wood cause a burner to ignite and will not turn off.
Is there an orange glow in the burner area when this happens? If so then the thermostat is not shutting the ignitor off and needs replacing. If there is no glow then the gas valve is not shutting off the gas and needs repalcing
Oct 10, 2014 | Whirlpool Kitchen Ranges
I HAVE A KENMORE DRYER, MODEL # 110.78652700 AND THE BURNER DOES NOT IGNITE. DRUM TURNS BUT NO IGNITION. ANY IDEAS?
check to see if the ignitor is lighting,, if it is,, then you need the coils replaced, on the burner control,, this link shows where they are http://www.applianceblog.com/mainforums/sears-kenmore/17748-kirkland-gas-dryer-no-heat.html if the ignitor isn't glowing,, replace it
Aug 22, 2011 | Dryers
My element turns on and the gas will light ocasionally.
If the igniter is glowing and even sometimes lights the burner, it's not the igniter that's bad. I've created a checklist that most homeowner's can use to trouble shoot dryer lighting problems. Click on my username, scroll down my profile to my tips and tricks for trouble shooting gas dryers.
Hopefully, one of these tips will solve your problem. Good luck.
May 18, 2010 | Amana NDG2330AW Gas Dryer
Gas oven not firing.ignitor not glowing.burners work fine.oven has been used in past for kitchen heat in winter months non low temp
dont use the oven for comfort heating not a good idea,, u prob need to replace that glow bar or ignitot part, gonna need ur brand and model number u ccould look up schematic at sears good luck
Jan 28, 2010 | Hotpoint Ovens
Kenmore gas stove, broiler works but oven won't light, igniter glows but thats it.
Hello, I'll start by saying this may sound odd considering the info you provided, "ignitor glows...". It is actually the ignitor you'll need to replace. Being that I do service for sears I've replaced numerous ignitor's, both bake & broil, but bake being most common as it is typically used more frequently. I'll try to explain... The simpliest way to put it is this, the hot surface ignitors function like a large resistor. As the ignitor glows it reaches a value to allow the gas valve to open and lite the burner. If the ignitor is even slightly worn/off it won't ignite the burner, hence it need's to be replaced. Hope that help's explain what & why. If so please take a second to rate the solution I provided here at fixya. Good luck and thanks for visiting fixya. Macmarkus :)
Dec 11, 2009 | Kenmore Kitchen Ranges
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Burners & Broil work but Oven burner does not!
HI thanks for your question. the problem is with the bake igniter. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
SEARS GAS STOVE MODEL#79072114100.OVEN WONT LIGHT,IGNITER GLOWS BUT NO GAS COMES OUT.IS THE GAS VALVE UNDER THE BURNER WITH THE 2 WIRES ON IT? VIC
i had the same problem ( ignitor glows but no gas) on sears model
79071012300. i replaced the ignitor (glow bar) and the oven lit within 10-15 seconds! it was easy to replace and it took longer to figure out how to get the broiler drawer out of my way than it took to replace the ignitor.
Jul 18, 2008 | Kitchen Ranges
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Bake burner
billsr, he may be right, however, sometimes the ignitors will cause this problem. They have to draw enough amps to open the gas valve all the way. Even though they glow, they may be weak and not open the valve completely. Attached is a diagram of how the system works. Catriver...post back.
Sep 28, 2006 | Kenmore 36692 / 36694 / 36699 Gas Kitchen...
Nexgrill 720-0234 (LP) Logo
51 people viewed this question
Top Nexgrill Grilling Experts
80stech
Gary Kenady
Gary Kenady
Michael Vincent Cruz
Are you a Nexgrill Grilling Expert? Answer questions, earn points and help others
