Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
Hi all. i updated firmware on c364e before installation and i made a mistake with gradation adjustment, i can print nicely but when i make copiers it makes the A4 lines, how can i fix this problem? i have been trying to start afresh but it is not helping.
  • Konica Minolta Master
  • 6,696 Answers
Have tech come out do the correct set up procedure
Posted on Dec 30, 2015
How to solve konica minilta c224 machine c2558 error
SHAKE THE BLACK IU VERY WELL Clean Imaging Unit Contacts RUN GRADATION
UPDATE FIRMWARE
REPLACE BLACK IU
Jun 29, 2013 | Konica Minolta Bizhub C224 Color Copier...
Irc6800 light copy problem
Try going into the user mode & press the adjustments and cleaning and then press the gradation adjustments and run a Full Gradation adjustment. Just follow what the display screen tells you what to do.. Good Luck
Jun 08, 2012 | Canon imageRUNNER C6800 Copier
Fault/error a fault has occured switch off the machine . ensure that the screen desappears before swithing it on. it the problem persists,call for service. 124-315
Solution : Perform an Automatic Gradation Adjustment (Color Calibration) Automatic Gradation Adjustment compensates for tones when the color tones shift in color copies / prints. Compensating for color tones maintains the quality of color copies / prints made by the machine at a fixed level.
NOTE: Output of the Automatic Gradation Adjustment chart is added to the metered copy count.
NOTE: When Gradation Adjustment is selected, the following changes will be made to default copy settings set in System Settings mode:
  • Copy Density = Normal or Auto
  • Color Shift =Normal
  • Saturation = Normal
  • Color Balance = 0
  • Sharpness = 0
  1. Press the [Access] button (key symbol) on the Control Panel. The Access button is located above the number "3" on the numeric keypad.
  2. Using the numeric keypad, enter your administrator password and select [Confirm] on the Touch Screen. The System Administration Menu screen will be displayed.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  3. Select [System Settings]. The System Settings screen will be displayed.
  4. Select [System Settings] again.
  5. Select [Common Settings].
  6. Select [Image Quality]. The Image Quality Adjustment screen displays.
  7. Select [Automatic Gradation Adjustment].
  8. Load 8.5 x 11 inch (216 mm x 279 mm) or A4 (210 mm x 297 mm / 8.3 x 11.7 inch) paper in Tray 5 (Bypass Tray). Adjust the paper tray edge guide so that the guide gently touches the edge of the paper stack.
  9. Select the desired gradation adjustment screen.
  10. Press [Start]. The Adjustment Chart is output.
    NOTE: When printing the color chart for Auto Gradation and you get the message,'Auto Graduation Procedure has completed with an error' make sure that 8.5 x 11 inch (216 mm x 279 mm) paper is loaded into Tray 5 Long Edge Feed (LEF).
  11. Place the Adjustment Chart face-down on the Document Glass with both the Magenta color patches against the left side of the glass.
  12. Place 5 sheets of white paper on top of the Adjustment Chart and close the Document Glass Cover.
  13. Press [Start].
  14. To continue Automatic Gradation Adjustment with other screens, repeat steps 6 to 10. When you are finished, select [Close] until the System Settings screen is displayed.
  15. Select [Exit] to exit the System Settings mode.
Hope it helps!
May 02, 2011 | Xerox CopyCentre C128 Copier
Cyan and majenta tone is not good
  • Color Balance = 0
  • Sharpness = 0
  13. Press [Start].
Hope it helps!
May 01, 2011 | Xerox WorkCentre M-24 Color Copier
Faint printing on samsung ml7140 laser printer -- even when cartridge is new
try adjust the toner aditiute by going in to the printer properties. adjust to 3 if posible and do a test print. If the print out is still faint. try update the firmware of your printer by going to www.samsung.com
May 15, 2010 | Samsung ML1740 Laser Printer
Reds come out yellow, and facial tones are too red
It sounds like your machine needs to be calibrated. First try turning the machine off and unplug it for about 15 seconds. When you turn it back on it will reboot its software and stabilize the image units. If this does not correct the problem you can perform a gradation adjustment by:
1 Load 11 × 17 L-size paper into the 1st drawer.
❍ Letter C, A3 L or A4 C can be loaded instead.
2 Press the [Utility] key.
3 Touch [Admin. Mode].
4 Using the keypad, type in the administrator code.
❍ Touch [Enter].
5 Touch [Gradation Adjustment].
The Gradation Adjustment screen appears.
6 Press the [Start] key.
A test pattern is printed.
7 After the test pattern is printed, a screen appears, indicating how
the test pattern must be loaded.
8 Place the printed test pattern on the original glass.
❍ Align the edges of the printed test pattern with the document scales.
9 Place into the 1st drawer 10 more sheets of blank paper of the same size as the printed test pattern page.
10 Close the original cover, or the reverse automatic document feeder if it is installed.
11 Press the [Start] key. The printed test pattern is scanned.
12 Based on the scanned image, the gradation levels are automatically adjusted.
After the gradation levels are adjusted, the Admin. Mode screen appears again.
13 Repeat steps 5 through 12 three times.
14 Touch [Exit], and then touch [Exit] in the Utility screen.
May 11, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
New Konica bizhub C351 copier with only 58 copies. It will make copies but it has a 6 1/8" x 8 5/8" BLACK area in the center of the 8 1/2" x 11" copy if you make a copy from the platen glass. It does not...
Gray box after installation.
Solution
CAUSE: Installation procedures were not completed properly.
SOLUTION: Complete the installation procedures thoroughly:
1. Adjusting Touch Panel - Press the Accessibility key, Touch Panel Adj.
2. Setting Gradation Adjustment - Go into Service Mode, Image Processing Adjustment, Gradation Adjustment. Service mode- ulilty/counter, check details , then(Stop00 stop01)
3. Touch High Compression Mode and press Start [perform 3 times].
4. Touch Gradation Mode and press Start [perform 3 times].
5. Touch Resolution Mode and press Start [perform 3 times].
6. Date/Time Setting - go into Service Mode, Press Stop, 1, 1, 4, 4, Clear.
7. Go into Utility/Counter, Administrator Setting, System Setting, Date/ Time Setting.
8. Install Date - go into Service Mode, System 1, Install Date.
9. Serial Number Input - go into Service Mode, System 1, Serial Number [If Serial Number is already there, Clear and re-enter it].
10. Unit Change - go into Service Mode, System 2, Unit Change.
11. List Output - Please Load 8.5x11 Landscape paper on Tray 1, go into Service Mode, List Output, and Touch Machine Management List and press Start.
12. Press Adjustments List and press Start.
13. Press Service Parameter List and press Start.
14. Press Fax Setting List and press Start.
Sep 04, 2009 | Konica Minolta Office Equipment & Supplies
Color copying gray turns out magenta. this happens when copying from glass only , printing from workstation it's ok..
try to run auto gradation adjust press * with head then go to adjustment/cleaning and follow the instruction or check the optical mirrors for dust contamination if is dirty you can remove 2 screws and remove the glass then wipe all the mirror with lint free paper or cloth( do this first before running the gradation adjustments)
Jul 15, 2009 | Canon imageRUNNER C3200 Copier
I have a Konica Minolta Bizhub c351 and all of a sudden it started printing everything with a pink hue and the colors are very uneven.
There is a long process to solve the problem I might suggest that you have to call for service. It might be the magenta developer unit might be bad or rich the max life that need to be replace. Or just plain adjustment on colors setting. It might need to update the firmware to the newest level.
Mar 27, 2009 | Konica Minolta bizhub C351 All-In-One...
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
71 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
