Question about Xante PLATEMAKER 4 Laser Printer
Cover open? I opened and closed all covers and it still will not print
    New Friend:
    Problem Solver:
  • 9 Answers
Dear its your Platemaker 4 front cover open massage i think please check its right behind the front panel,its not easy to check it first removed the panel cover side cover after that formatter board,fuser assembly you can observe that its communicate with gears,found in main engine there is small lever who controlled front cover,hope you understand.
thanks.
Posted on Aug 18, 2016
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
When I try to print, I get the error: Top Cover Open: The printer cannot print because the top cover is open. How do I fix this?
Hi cduckyquack ,
  • All you need to do is close the printer cover if it's open , once it's closed you should be able to print correctly without any warning messages.
  • If the cover is closed and still you are getting the same message , then it might be a problem with the censor switch which indicates to the printer whether or not the cover is open, so if the switch / sense has gone faulty then you need to repair it.
  • Sometimes just because of dust the printer does not sense the cover being closed and it results in the error message that you have described.
  • Hope this helps ...) your feedback would be appreciated.
Jun 02, 2011 | HP DesignJet 1050c plus InkJet Printer
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
Printer says cover is open and its completely shut. wont print
Maybe something wrong with sensor which displays the state of the cover.
Try to find it.
May 31, 2009 | Dell 926 All-In-One InkJet Printer
Top cover open error when printing
I had the same problem and fixed it by sticking the end of a pen (the writing part) in the hole on the right side when you open the top cover.
In other words if you open the top cover and look on the top cover you will see a tab that goes into a hole(the hole is next to the picture of the print cartridges). There is a hole with switch/tab(I don't know the proper terminology) on it that is activated when you close the top cover. If you stick the end of a pen in that hole it should activate something and the print cartridges will start to make noise and move around. You can then close the cover and it should close all the way.
You can then try to print a test page.
Good Luck
Dec 13, 2008 | HP DeskJet 5650 InkJet Printer
CD printing error 'inner cover is open'
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Closing the inner cover to clear error messages.
  1. Raise the Scanning Unit until it stops.
    (A) Press the Open Button to open the Paper Output Tray if it does not open automatically.
  2. Close the Inner Cover
  3. Close the Scanning Unit.
I hope it helps!!!
Nov 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Hp deskjet5650
When closing the cover very slowly do you feel at the very bottom before it "closes" a slight resistance?You should have to push it down to finish the movement. Simply let the lid rest on your fingers and lower it into place, if there's no resistance just at dead bottom then the physical tab attached to the pegs of the cover may have broken off. The swich to "close lid" is probably internal by the lid joint.
Check to make sure the print carriage isn't snagged either. any little piece of anything can cause problems.
Good luck.
Sep 05, 2008 | HP DeskJet 5650 InkJet Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Open Questions:
See all Xante PLATEMAKER 4 Laser Printer Questions
32 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
