Question about Philips Audio Players & Recorders
Selecting MP3 drive shows - can't find script file.
When I click on The MP3 Drive, it shows, can't find script file "I:NewVirusRemoval.vbs"
I called ALTEC LANSING service center usa after getting # OFF SERVICE CENTER WEBSITE. I DIDN'T SAVE THE SITE DATA. STEVE
Posted on Jun 23, 2009
How do I get rid of message when I turn on computer it says can not find script file "X:onekeymainIrscall.vbs"?
  • Press ctrl + alt + del
  • Select task manager
  • Click on the Start Up tab
  • Disable the entry associated with this vbs script
Jun 07, 2015 | Lenovo Computers & Internet
The DVD Driver was disappear!
This could mean you have motherboard problems, or the drive died... however, the most common issue is windows registry corruption. Right click this link and save the vbs script to your hard drive: Restore CD/DVD in Explorer Navigate to the folder where you downloaded the script file. Ifyou are running Vista or Windows 7 you may have to right click the file and select run as administrator, else if you are running XP just double click the file and follow the prompts. Basically the script deletes some entries in your system registry that cause the CD/DVD drive to be "re-detected" the next time you boot your computer, so once done, restart your PC and in most cases, once you are back in windows, your CD/DVD drive will show up again.
IF this doesn't work, there is a big chance your drive is no good and will need to be replaced.
Hope this helps!
Regards, Chris
Jul 01, 2011 | Acer Aspire 4520-5582 Notebook
Can not Find. Script File C:\WINDOWS\System32\CleanViirus.vbs
it is a virus plz follow the instruction bellow to remove this virus:
  1. Go to Task Manager –> Processes and End the following processes in order:
    1. dxdlg.exe
    2. wscript.exe
  2. Go to Start –> Run –> regedit –> Open the following key:
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogon
  3. In the right hand pane, select Userinit and delete everything except “C:windowssystem32userinit.exe”
  5. Make sure the processes wscript.exe and dxdlg.exe are not running.
  6. Delete the following files
    1. C:WindowsSystem32dxdlg.exe
    2. C:WindowsSystem32boot.vbs
    3. In your Windows drive, search for boot.vbs and delete all of them.
    4. In your Windows drive, search for kinza.exe and delete all of them.
  7. Disable System Restore and then Enable it again.
  8. Restart your computer.
Hopefully everything will be cleaner now and your computer will be free from boot.vbs virus icon_smile.gif . Please share your experiences.
Mar 31, 2010 | Microsoft Windows XP Professional With...
My computer is not creating Restore Points... yes it's turned on... yes I know how to do a manual... but it disappears when the next Restore Point is created... can you help?
Creating a System Restore point using a shortcut For a more elegant way to create a System Restore point using Script in Windows Vista, check out our article Create System Restore Points Quickly using Script in Windows Vista and Windows XP.
Alternately, you may use the method below:
Copy the contents below to a Notepad document, and save it to a file name with .vbs extension (Example: createrp.vbs) and close Notepad.
set SRP = getobject("winmgmts:\\.\root\default:Systemrestore")
CSRP = SRP.createrestorepoint ("Created a Restore Point now", 0, 100)
If CSRP <> 0 then
Msgbox "Error " & CSRP & ": Unable to create System Restore point"
End if
Right-click on the Desktop and select New - Shortcut
Create a shortcut with the following target:
wscript.exe c:\scripts\createrp.vbs
Note: The above assumes that the createrp.vbs script is present in the c:\scripts folder. If that's not the case, change the Path accordingly.
Name the shortcut file name as Create Restore Point
Running the script To create a System Restore point, run the script with elevated mode. To do so, right-click on the newly created shortcut (Create Restore Point.lnk) and choose Run as administrator. When you are prompted for an administrator password or confirmation, type the password or provide confirmation. A System Restore point will automatically be created.
Nov 23, 2009 | Microsoft Windows Vista Home Premium with...
When I open my pen drive I get a message Cannot find script file "G:cleanvirus.vbs"
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Jul 16, 2009 | Samsung SGH-D900 Cellular Phone
Can only acces my pictures and it's files by rt clicking only. If I left click it goes to search. I have HP Pavillion dv 5120 us notebook laptop.
Download folder_open.vbs and save this file to your hard drive.Navigate to where you saved it and double click the file. A confirmation dialog will appear when finished. This script can be viewed in Notepad or any text editor, as to the specific Registry key and value that are updated.
http://www.dougknox.com/xp/scripts/xp_folder_open.vbs
Mar 08, 2009 | HP Pavilion dv6000z Notebook
Can not find script file "C:\ntidr.vbs"
by alvin:
just go to command prompt, click run then type cmd..
after that type dir f:\/a/w if letter f is where your drive located..then you can see the contents of your drive ..you will see an autorun.inf...
you should delete that...in the same cmd window
type attrib -r -a -s -h f:\autorun.inf
then type del f:\autorun.inf....eject your flashdrive...goobye ntidr.vbs..
Sep 21, 2008 | Microsoft Windows XP Home Edition
Problem while starting computer
Hello..
TO remove this error messege follow these steps.
type "regedit" in run dialog box.
Navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon"
There is a string value named "userinit".
The value of this key should "c:\windows\system32\userinint.exe"
Delete anything thing after this.
Now logoff and relogin or Reboot.
Jun 09, 2008 | Computers & Internet
Script Virus Removal particularly VBS.IE-Title.K
Eexecute regedit by typing "regedit.exe" in run command or command prompt.
Search and Remove the key value present in the reg'ed values in
HKEY_CLASSES_ROOT & HKEY_CURRENT_USER & HKEY_LOCAL_MACHINE & HKEY_USERS & HKEY_CURRENT_CONFIG , If present
this may present in /software/microsoft/windows
or drives/
Jan 18, 2008 | Microsoft Windows XP Professional
Missing file after avg "healing"
Yes easy fixed. Open from my computer then go into folders options and click on show hidden folders option, your system folder should show up then open that folder and youll see the vbs file. Delete it, and all is good !
Jan 08, 2008 | Samsung Yepp YH-J70 Digital Media Player
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
