Question about Microsoft Windows 7 Ultimate for PC
Need a batch file to change the ip and gateway as well as the computer name
    Master:
  • 680 Answers
Ip addresses are controled by your isp contact them and see if they will help you to change it. You don't need a file to change the computer name right click on Computer choose properties. On the upper left side click on Advanced System Settings. In the new window click on Computer name. Click on change computer name . After you changed the name make sure you reboot then your computer name will be changed to what you changed it too.
Terry
Posted on May 13, 2014
How do I change the security key of a wifi network?
  • IP into your your router/switch. If you don't know the IP then get the IP of any wireless device or computer attached to it.
  • For Windows your can click on the "Start" icon then in "search for programs and files" box type "cmd" then enter "ipconfig".
  • The address for the router will be the "default gateway address". See attached image.
  • Enter this "default gateway address in a browsers address.
  • The router should prompt you for a username & password.
  • User name is typically Admin. Do a google search for your router brands default password if you don't know the password.
  • Enter the password then you should have access to the router configuration menu. The SSID and security key are going to be under the WiFi settings.
If you provided the Router make & model I could give you more specific info.
Jun 25, 2017 | The Computers & Internet
Need a bat file that will change IP, Gateway and name of computer
download windows 7 all editions activated from piratebay and install it.
May 13, 2014 | Microsoft Windows 7 Home Premium 64BIT...
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
May 2008 domain controller is up and running but i cannot join it with my windows 7 laptop, "domain path not found"
Ah this is an easy one, make sure the laptops MAC address (this can be found by going into the laptops command line and typing 'ipconfig /all') Then you need to go into Doman users and computers (active directory) and add that MAC address to the computers group.
If this doesn't work...make sure your laptop is connecting through the same network. use the cmd line tool Ipconfig /all to find out the ip address of your server and your laptop. If your laptop's default gateway doesn't match that of your server's...you could be cross networking. Try the "ping" command like this go to the command line on your laptop and type Ping <ip address for server> if you can ping it, you can connect with it....also check your group policy that enables wireless connections.
Dec 15, 2009 | Dell Dimension 3000 PC Desktop
I cannot share file now that this router has nbeen installed
Make sure all computers has ip address in range with router.
Set gateway in all computers as your routers ip also enable DHCP in router.
Then you can share files and computers.
Make sure that sub net mask is same and gateway is your router ip in all computers.
Let me know if you need further assistance.
Thanks for suing FixYa.
Dec 01, 2009 | Zhone (6218-I2-200) Router
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
I am trying to set a network using a wired desktop and a wireless laptop (desktop using XP and laptop using Vista)I am using a Linksys WRT160N, I can get on the internet with no issues at all but when...
in the router's lan (not wan) configuration - set the dhcp server (gateway address) to be 10.1.10.1. Then set the addresses of the clients (connected to the router) to be assigned addresses from 10.1.10.10 - 10.1.10.20. Set the desktop's TCP/IP address to be 10.1.10.11 (static) with a subnet of 255.255.255.0, and a gateway address of 10.1.10.1. Set the laptop's wireless connection (TCP/IP adapter) to have a static 10.1.10.12 address with same subnet mask and gateway address of desktop. Change the workgroup on both computers to be of the same name (case sensitive here) to a name such as HOMENETWORK. Then on each computer, open up "My Computer" and right click on folders, files or printers that you want to share on your network!
Sep 26, 2008 | Computers & Internet
Microsoft Windows 7 Ultimate for PC Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
