Question about Bush WS6671 28" TV
Tv will not turn on when you press the main power button
When you try to turn on tv from the main power button, it does not do anything , except makes a strange noise from inside the tv , like a squeaky sound , as if something is trying to work, The set is about five years old.
Re: tv will not turn on when you press the main power...
Sounds like the line output transistor is shorted look for a repair kit for your model
Posted on Dec 01, 2008
0 characters
3 Points
My haier htr20 tv wont power is completely dead.
Check the main power regulator section circuit.
May 20, 2012 | Haier HTR20 20" TV
My tv is an old rca tv, i have a dish network remote, one of the kids locked out the tv and i dont know how to get it back on, it wont tell me a anything all i can do is change the tv with the remote,...
If I read your post correctly it sounds like, the remote no longer works the volume or power for the TV set. If this is correct follow the steps below for a Power Scan. If this is not the issue or the steps don't work feel free to contact me and we will sort this out!
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Try several functions Mute Volume and Power to make sure the remote works properly then press "SAT".
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | RCA 32F531T 32" TV
Says no signal on screen while hooked up to cable box and will not change channels
First, make sure the cable box is correctly connected and power is on and try pressing the "TV/DTV" button in the top right corner of the ORIGINAL Sylvania remote. If this doesn't work, try pressing the "MENU" button and make sure the menu displays. If the only button that works on the remote is the red "POWER" button then it's likely your main A/V board will need replacing.
Try the above and post back if you need further assistance.
Dec 06, 2010 | Sylvania 6432GG 32" TV
Sony KV-32FS12. Buttons on the TV don't work, the remote don't work. Now stuck in one channel. Can access Menu with TV button but can't go anywhere. Unplugged from main power source still no go. Tried...
Your TVs front control buttons are inoperative except menu button. There are microswiches fitted inside the main board of your tv from which shafts ar extented towars the front of the cabin where you press to access the functions. Replace all the micro swiches inside at onetime. It won't cost more. Micro swiches as they have said is mini swiches, which can get damaged easly with high pressure thumb or impact put on it.
Oct 15, 2010 | Sony KV-32FS12 32" TV
RCS 14F512T 14" TV
possibly one of the switches behind the front buttons is shorted;
could one of the front buttons be pushed in and not releasing-maybe the power button?
Apr 29, 2008 | RCA 14F512T 14" TV
I think the ploblem should be the horizontal output that may be shot circuting working voltage,
apperently if you are not a qualify technician I recomend that you seek the help of such technician
Dec 11, 2007 | Bush WS6671 28" TV
TV doesnt have a picture but power button flashes
I have a suggestion you need to check the regulator if you have a mutitester it would be this is a job for a technician .
Nov 29, 2007 | Sony KV-32S26 32" TV
Locked out of TV
Use two buttons on the tv at the same time, hold four seconds.
Try menu & power or vol up & chan up.........
Nov 04, 2007 | Standard (CRT) Televisions
Sony trinitron messed up
pressed a bunch of butons on the tv and the remote means first of all it is due to that buttons as they might be loose fron inside or broken contact. if remote & tv buttons ok check for sound section in tv. if you are not tech person get tech help it is a simple job.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Standard (CRT) Televisions Logo
127 people viewed this question
Top Bush Standard (CRT) Televisions Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bush Standard (CRT) Television Expert? Answer questions, earn points and help others
