Question about Canon Office Equipment & Supplies
How can i clear the memory on a Canon ir1024 to enable me to scan documents to e-mail?
  • 59 Answers
SOURCE: scan 5 separate documents into 1 e-mail instead of 5 e-mail
I'm assuming you have pressed SEND button at top.
There is a DIVIDE INTO PAGES button towards the bottom right, if it's a blue colour press it to make it grey, this will send the docs as one file.
Posted on Mar 26, 2009
SOURCE: insufficent memory to send scanned document
What model? If it has a touch screen do what it says: In "scanner mode" touch the "status" button on the screen..all scans show up with the status.Touch the appropriate scan, and touch "delete" (or cancel)
Posted on Mar 30, 2009
cropp
  • 377 Answers
SOURCE: Can not clear memory on PIXMA Canon MX700
dear david
try this
) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release
the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons.
(Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green,
starting with Alarm LED.)
4) When the Power LED lights in green (and "Service Mode Idle" is displayed on the LCD), press the Stop/Reset button 4 times.
5) Press ON/OFF, press Stop/Reset 2 times
6) Press ON/OFF. Unplug printer and plug back in. turn on and should be cleared
oke , post me back
cropp
Posted on Apr 10, 2009
iservice
  • 318 Answers
SOURCE: MY PRINTER IS NOT RESETING AS THERE IS JOBS IN THE
Press the monitor buttton.The buttonwith a square and a eye sign.Scroll with the arrows until printer log is display.Press ok,and follow the instructions to erase the job.
Posted on Sep 15, 2009
SOURCE: How do you clear scanner
Let the machine send the document first before scanning another document
Posted on Dec 03, 2010
How to clear scan data
Your machine will show 100% and that is correct. It doesn't mean memory full, but rather the amount of memory that is still available. Once you scan a document you will see the memory drop down to 99% or even lower depending on the size of the scan. If you don't see this happening than you are not scanning. Other than that your scan will either go to a folder on your PC or straight to your email. All you need to do is locate the folder it saves your scan in (usually created in your C: drive) or check your email folders including your Spam/Junk mail folders.
May 25, 2016 | Ricoh Office Equipment & Supplies
I want to scan a document to send to email how do I do this
scan the document , save to your pc , laptop , then when wanting to send on attach it and send
Mar 15, 2016 | Canon PIXMA MX432 Office All-In-One Inkjet...
Canon 2030i scanned document in memory - Need to clear
you follow this step :
- press button ADDITIONAL FUNCTION
- press button number 2 and 8 (press simultaneously with two fingers)
- press button ADDITIONAL FUNCTION again.
service mode will come out on the screen
- press FUNCTION on the screen
- press CLEAR
- press R CON
- press OK (bottom right side of the screen)
- swicth OFF the copier
- wait for 3 or 5 second
- swicth ON the copier
GOOD LUCK
if you need more, you can email me
Feb 22, 2013 | Canon ImageRunner 2030I Black and White...
Error E100 on Canon iR1024A
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
Jan 31, 2013 | Office Equipment & Supplies
Canon ir1024 given error 000
turn onn the mechine press star button of additional function and press 2 then 8 for same time then press star select copier option then function then clear then err then ok restart the mechine it will work
hope soloution help you
Sep 05, 2012 | Canon Office Equipment & Supplies
Is Canon ImageRunner iR2200 scanner working with Linux/Ubuntu?
It's pretty easy - you can do it from the HTTP interface.
You must have the jbigkit installed (check your distro's repository for jbigkit or go to http://www.cl.cam.ac.uk/~mgk25/jbigkit/ to download a tarfile).
First, enable the HTTP interface in the copier setup. Then, at the copier:
  1. Place your document on the glass or in the ADF
  2. Push the "Mail Box" button
  3. Select a mailbox (i.e., "01")
  4. Click "Scan" on the screen
  5. Push the Start button to scan the document into the mailbox.
In your web browser:
  1. Type the IP address of the copier into the navigation bar and hit Enter
  2. Click on "Mail Box" on the left
  3. Select the mail box that you specified at the copier when you scanned the document
  4. Click on the appropriate document (if there is more than one, determine the correct one based on the date/time)
  5. For each page of the document scanned:
  1. Click the little page icon under "Size (Mono/KB)"
  2. Click "OK" in the warning box that pops up
  3. Rename the image.jbg file that is downloaded to a more appropriate name, i.e., documentname-pageX.jbg
From the command line, you can convert the file to .pbm using the command:
jbgtopbm <.jbg filename> <new .pbm filename>
from the jbigkit.
See also:
http://www.linuxquestions.org/questions/linux-software-2/jbg-image-viewer-converter-787703/
Jul 31, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Scan documents and e-mail
was there a utility or a cd that came with the printer, and is there a scan button on the printer? That might be easier to do if you have Canon's software, however, if you dont, or dont want to look for it (haha, i wouldnt), you can go to this website and follow its instructions on how to scan a document using windows. The instructions are very clear (they are on the microsoft website) and are made so that anybody can understand them. If you have any problems, feel free to contact me. Or, just post another thing on here.
Aug 08, 2008 | Office Equipment & Supplies
91 people viewed this question
old marine
old marine
