Question about Refrigerators
I have a True Refrigeration TDBD-72-2 and the front light won't come on. Is there a ballast for this light and if yes where do I find it.
3 Suggested Answers
  • 112 Answers
SOURCE: ballast
You haven't supplied a model number... Makes a big difference. Generally speaking though you pull off the bottom louvered section and it will be inside of a post where the condensing unit plugs in or mounted against the sidewall.
Posted on Jul 07, 2009
  • 884 Answers
SOURCE: top coils don't get cold on a TDBD-72-4
Make sure the condenser is spotless. If it is suspect short of refrigerant.
Posted on Apr 14, 2012
No blue light after boot
Yes, I've seen the ballast bad after a lamp shorts out. It takes out a 1K resistor out in ballast. If original lamp blew up this could be your issue
Dec 29, 2013 | Toshiba 72HM195 72" HDTV
Lights not working, and can't find the ballast location
The ballast is located down by the compressor if you take off the cover the ventilation slats. Then in the very center where there is a plug from the compressor plugged into the side of the center support as a cover on the front of that open the cover and inside you'll find The ballast.
Mar 09, 2013 | True GDM-69 Refrigerator
Lights
check to see if there may be a switch if so check the switch to see if it functions, if the switch works fine you may have a bad ballast or the bulbs may bad
Oct 16, 2012 | True Deli-Cases TSID-72-4-L Refrigerator
Top coils don't get cold on a TDBD-72-4
Mar 30, 2012 | True Refrigerators
Replaced lamp, tv worked great for a week, yellow blinking status light, dust cover is secure and the switch is good. tv won't power up
Now the tv projection lamp tries to light up to the tv screen and shutting itself down,u hearing tv make alots of cliking noises to the tv set too?Yes,mean the Ballast board it is also dead,now must replaced the Ballast board too.The Ballast board only job are to ignite the tv projection lamp only.
Aug 09, 2011 | Mitsubishi WD62527 62 in. LCD HDTV
Where do i find the starters for the florescent lights on a true gdm-72
They should be located under the front access cover below the door. Under that cover there may be another smaller covered box that they may be located in.Make sure you disconnect the power source before removing any covers.
Nov 12, 2009 | True GDM-72 Refrigerator
Ballast
Jul 04, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Use of computer ups for lighting purpose
To your concern of using a computer type UPS to power other devices:
  • If the light is incandescent type, yes;
  • If the light is florescent type, depends on the design. Some yes, some no. If the ballast is electronic, yes; if the ballast is inductive, no;
  • on the fan, no.
To my knowledge, most low-end commercial UPS produces a square wave. Only high end (expensive) models produces true Sine wave.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 17, 2008 | Computers & Internet
Lighting problem
front center section behind the lower panel you will need to remove the front bottom grill to get to it
May 28, 2008 | True GDM-41 Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
