Question about Freezers
Need door seal for imperial UF2075CW6 HD Comm. freezer. Can't find the part number anywhere or the seal. Can anyone help?
5 Suggested Answers
jaylex
  • 417 Answers
SOURCE: freezer seal
Turn the machine on to full empty all contents and leave for about 30 minutes then try to close door if doesn't work check the seal for splits.
Thanks J
Posted on Feb 16, 2008
bobicehouse
  • 1524 Answers
SOURCE: Need seal for center door for comercial 3 door Delfield.
A good parts store will carry ready made gaskets, just bring a sample to match.
Posted on May 08, 2010
SOURCE: We have an imperial upright ''commercial grade''
just to be sure that your door is sealing properly, put a flashlight into the freezer and turn off all of the lights in the room to see if there are any openings in the seal. Iam suggesting you this coz sometimes a small opening may pass our eyes easily....
if the door is sealing properly......
If this is the type of freezer where the shelves are the evaporator coils, the coolant goes through the shelves(tubing) and the formation of frost is normal and has to be manually defrosted.All the shelves should be as cold asd the top one. The fact that just one has any frost may indicate that it is low on freon. If this is the case you should notice that the freezer doesn't get cold enought just like you said... so check your freon levels.
This could also be because of the thermostat not sensing when the fridge reaches its set temperature and as a result of this the compressor will keep on running and build-up of ice will occur.
Follow the advices in the order prescribed above and you should be set
Posted on Jul 27, 2010
oldTech2332
  • 2341 Answers
SOURCE: I have an Imperial heavy
The part number for that gasket is 216522312 it could be purchased from your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Posted on Sep 09, 2011
PARTS NUMBER
Hello Jerry;
My name is Peter. I am a retired field service refrigeration technician.
You need to provide a model number for me to give you the gasket part number and price. The model number is on a label in your fresh food section on the upper side wall.
You have a bottom freezer, Right? These bottom freezer drawers are had to seal all of the time. They can get off track and not seal properly. It is not uncommon for them to ice up around the door gasket.
Lets try this first:
1.) Clean the gasket.
2.) With a hair dryer and a kitchen spatula, Heat the gasket while pulling gentle out on the gasket, to expand the gasket.
3.) Run a piece of paper between the gasket and the freezer front. If you can do this, then you still do not have a solid seal.
Feb 25, 2015 | Freezers
My frigidaire automatic defrost upright freezer gets ice build-up at the top right at the front any suuggestions
This is just a general answer but it may mean that the door seal is leaking. Try running a dollar bill under the seal to see if that area is looser than the rest of the door seal.
Look inside the freezer for model number.
How to Check Freezer Door Seal DoItYourself com
Aug 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Our old Imperial heavy duty commercial model uf20x needs seal. Where to find it?
Commercial refrigerator parts supplier can make it same day. Check google for your nearest supplier.
Feb 01, 2014 | True 72 cu. ft. / 2039 liter Commercial...
I have an Imperial heavy duty freezer, model # UL2494ECW5. My door seal is ripped pretty good. Where could I purchase another rubber seal for that model?
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Sep 09, 2011 | Freezers
We have an imperial upright ''commercial grade'' freezer. The top shelf has 2 inches of ice on it. The rest of the freezer is not cold. Door seal is ok. freezer is currently unplugged and defrosting.
Jul 27, 2010 | Freezers
Apr 28, 2010 | Freezers
I have a Frigedaire Upright freezer, Model says
to verify what i think could be the problem i would need the complete model number so i can recheck what i am about to tell you
the freezer has a heater where the door gasket seals itself on (not on the door behind gasket but on the freezer itself) see if you can feel if it is warm where the gasket rest on the freezer this help it get that solid air tight seal. and prevent ice build up on gasket
well this maybe one possible without being there its alittle hard to tell what else hope this was alittle helpful
Mar 13, 2010 | Freezers
Freezer seal
Thanks J
Feb 01, 2008 | Freezers
Frost in Kenmore frost free
Although you say the seal is fine, this is almost certainly due to air getting in. With the door closed check that there isn't a tiny gap with a strip of thin card or plastic. Of course if air is getting in then it must also be getting out somewhere else so probe all around the seal.
Oct 01, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
63 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
