Question about Goodman Heating & Cooling
Unit attic fan will not shut off
Replaced the start up capacitor on out side unit ran fine for the last few weeks,yesterday noticed attic fan would not shut off ran all night now low out put like frozen over 90 degree day could not get temp below 80 degrees till one am went to 71 degrees only way to shut off motor was to turn off breaker,thanks Joe
  • 2 more comments
  • Joey
    Joey May 13, 2014
    a/c draining well nice puddle out side,checked evap cold no ice
  • Joey
    Joey May 13, 2014
    Hi Low side 65 si Hgh sde 20psi joeym
  • Joey
    Joey May 13, 2014
    sorry high side 200 psi joeym
  • George Andoniades May 13, 2014
    Low side 65psi is perfect make sure that the condenser in and out is clean
    New Friend:
  • 32 Answers
Check the freon
Posted on May 13, 2014
Testimonial: "low side about 75-80 psi low side cold high side hot evap not clogged,I would think on auto I would get a few speeds,only one I even took off the green wire on t-stat to see if motor would shut down no luck.Joey"
  • 340 Answers
SOURCE: Outside air temp around 100 unit wasnt cooling
90 psi suction too high possible bad valves or non condensablies in the system (AIR) what is the head pressure and what type of freon r-22 410-A? your unit is never shutting off watch out for that electric bill. and did you take apart the condenser and clean it? Tom
Posted on Jun 25, 2009
  • 52 Answers
SOURCE: 2 weeks ago one of my units stopped working
sounds like the coils inside the air handler/furnace are freezing up. likely cause is the freon charge is incorrect (probably undercharged). it may have been correct when the tech did the work but some may have leaked out. it is slightly possible too that the system is overcharged. you should have the system pressure verified, and then have it checked for leaks.
Posted on Jun 18, 2009
electrodynam
  • 35 Answers
SOURCE: thermostat window ac turns unit on and off 8 degrees above se
the unit may be drawing the cool air it just released back into itself,plus the air close to the unit may be a little cooler than the air in the rest of the room.
Posted on Mar 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: bought 2004 popup camper 3 weeks ago went to s.c.
Isolate the thermostat sensor. Hold it with your hand and see if it comes on and stays on. If so, replace the thermostat.
Posted on Jul 05, 2009
  • 2418 Answers
SOURCE: Water running through overflow
No, Do you mean that water is draining outside when it is running, if so, no need to be concerned. Yes yes yes be concerned if it is draining on to the ceiling.Get up there and ck the drain make sure the pan is tilted right to drain. ck the drain out side make sure it is free to flow. .
Posted on Jul 14, 2009
Unit fan in attic will not stop running
if the thermostat is calling for cooling the fan will run 24-7
May 13, 2014 | Goodman Heating & Cooling
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
Gmp 100-3 fan runs even when tstat is set to off an fan setting to auto. unit ran fine all summer in cool mode and was off for the last couple weeks. just notice the fan was on yeaterday. ran unit in...
Hello, one way to check is remove the green wire from the G termimal on the circuit board in the Furnace, if tn
His turns it off it may be a short in the tstat wiring or bad thermostat, if it does not turn it off the relay on tne control board is stuck and tne entire board must be replaced.
Sep 28, 2011 | Goodman GMS90703BXA Heater
I have a all in one or complete unit the fan motr
hopefully you replaced motor with the same Rpm HP Volts and made sure the rotation of fan was correct.. Might have a bad/defective motor I would take it back to whomever you purchased it from as the should exchange it. Good Luck
Jul 21, 2010 | Heating & Cooling
I just installed a master flow attic fan. I ran
Sounds like it could be a bad capacitor (black box on side of motor).
Jul 19, 2009 | Cool Attic Dryers
Jul 14, 2009 | Amana Heating & Cooling
Compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Jun 22, 2008 | Coleman Mach III Air Conditioner
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Heating & Cooling Logo
109 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
