Question about Carrier Heating & Cooling
Totaline P274-1200 flashing all characters
1999 Carrier Model 38BYCO48310 A/C Heat Pump; Totaline P27-1200. The display presents all the options on the screen simultaneously, then momentarily returns to the normal display, then E2, then back to all options (displays off, heat, cool, e heat.. fan is on and auto, the room temp is reading -HP, time 1888, all the days of the week, etc). I hear a distinct click sound at the thermostat as it flips between these three displays (all-options, normal view, E2). Came home to this, so that's all I have. The A/C isn't turning on as I would expect based on the programming, but I really cannot see the thermostat setting since none of the buttons seem to change the display. Any suggestions?
  • 32 Answers
Check the conections try contact sprey
Posted on May 13, 2014
Testimonial: "no change. in case it wasn't clear... the display is usually on the all-options, then momentarily displays the normal screen then E2, then back to the screen with all the text displaying."
  • George Andoniades May 14, 2014
    usually E2 is the indoor temperature sensor
The HVAC Guy
  • 30 Answers
SOURCE: Goodman GSH130301AB heat pump with
the reversing valve wire needs to be on the o terminal.nothing will be on the b terminal on the thermostat
Posted on Oct 30, 2008
  • 20 Answers
SOURCE: No heat new thermostat
you have a short in the wireing.disconnect at air handler and hook-up short t-stat wire to t-stat,ifok chk wire to condenser
Posted on Jan 10, 2009
tborn6
  • 700 Answers
SOURCE: My outdoor heat will not
you need to go oside and look for a red reset button on the unit. you tripped the high ressure switch when you let your filter get that dirty. go check on this and when your done if it still is not working then ask me more.
Posted on Jan 25, 2009
mastatech
  • 478 Answers
SOURCE: Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Posted on Mar 11, 2009
kingbrizzle
  • 407 Answers
SOURCE: problem with mitsubishi air roof units
The thermostat would need to be insulated better from the air that is surrounding it. Im assuming that the thermostat is located on the wall unit where it blows out the air. This could mean that it is actually reading more from the outside temp, than whats inside the house. Another thing to consider is the location of the thermostat, even it being close to anything in the house that produces some kind of heat will effect the condition of the air. If anything, its the manufacturers mistake if it was properly installed in the first place and if defective, they should replace it. hope this helps.
Posted on Dec 28, 2009
Thermostat Totaline P7470100
It's probably the liquid crystal has a crack and is flowing inside the glass. It can only be repaired with a new display.
Why not contact Totaline directly and see what they can offer?
Contact Us Totaline
Jul 21, 2016 | Heating & Cooling
I am replacing a Totaline p274-0200 with a Focus Pro TH6110d. We have a 1H/1C Electric Heat pump with an emergency heat option. Not sure how to wire the Focus Pro.
R=red g=green o/b= orange blue=common y=yellow w=white do you have heat strips? Is u do u have 2 heat 1 cool no u have a 2 get one cool can u send me a picture of the wiring on the old stat
Sep 24, 2015 | Heating & Cooling
I have no idea how to use my totaline digital thermostat,
Totaline is a brand name of the Carrier Corporation. Go on www.totaline.com and research the model of your thermostat. User manuals are available.
Nov 11, 2013 | Heating & Cooling
Totaline thermostat P274-0200 just stopped working...can't figure out why,
check condenser fan line. over heat condenser so have not cooling in home.no cooling so Thermostat not worked.if it's ok. check Thermostat volb lick .
May 28, 2012 | Carrier Totaline P291-1003 Capacitor 10mfd...
Heat comes on when the temperature setting calls for cool.
getting heat in the cooling mode leans toward the reversing valve in the outside unit. it changes the flow of refergerint so that the hot air you get outside in the summer is blown inside in the winter. another possibility is that the reversing valve isn't getting 24v check to see if you have 24v at O and C either at the t-stat, furnace, or the outside unit. if you check at the furnace rember the safty switch for the lower door if that switch is open you will have no power. i would look at the t stat first if you have 24v there go to the outside . 24v present outside will mean a bad valve or board, no 24v means a bad or broken conection in the control wire between the stat and the outside unit(usally the orange wire)
Jul 10, 2010 | Carrier Heating & Cooling
I need a wiring diagram for my carrier heat pump MOD 38YCC030300
call ur carrier supply house near u they will be able to help u unless they r too lazt to help but they have access to all that someplace like whittichen supply or totaline or weathertech
Feb 20, 2010 | Heating & Cooling
Six wire hook up and new thermostat has only 5
Some thermostats have an extra terminal for an outdoor sensor which tries to anticipate the need for heating or cooling. If this option is not present, you will have an unused terminal which may have a shorting link to a neighboring terminal. Your installation instructions should mention this if the option is or is not included with your model. Also, heat pump systems vary in the system control voltage and not all thermostats and systems are compatible with the more common split system thermostat.
Oct 01, 2009 | Honeywell Electronic Programmable...
Where can I find a copy of the schematics for an older model carrier heat pump
Find your closest TOTALINE (Carrier parts dept) and see if they would be kind enough to give you a web link or print it out. You can try the carrier website, parts but I think one has to be registered with carrier to access that information.
May 06, 2009 | Heating & Cooling
I'm COLD!
Any will work provided you have it is a Heat Pump thermostat. I recommend honeywell or totaline.
Dec 05, 2008 | Ruud UBHC Air Conditioner
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
117 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
