Question about Calligaris Ice Bar Stool CAL-CS-1050/P77_P266
My perspex seat has snapped at one corner
It looks like the seat part can be replaced using allen keys. do you know where I could get another clear perspex seat from please
How to open the seat?
if u look at the rear of main seat on left side near passenger foot peg u will c a slot for your key to go in, turn it to the right and it will unlock passenger seat and then pull up on the seat. if u r talking about your main seat there r two bolts one on each corner of the seat in the back lift corner up to see them u will need metric allen wrench
May 17, 2011 | 2001 Yamaha YZF-R1
HOW TO REMOVE A GSXR 750 SEAT
Rider seat It should have 2 allen bolts on each side of the seat. At the back of it. Just lift up the rear corners of the seat and you should see one on each side.Hope this helps you out
D.
Sep 30, 2010 | 1999 Suzuki GSX-R 750 X
How do you remove the seat from a 1996 honda shadow vlx
Hi, There are two allen key screws that keep the pillion seat secured down. The riders seat then slides backwards to remove. Have a look inbetween the riders seat and pillion seat from either side of the bike. Prise the gap apart with your fingers and look inbetween. About an 30mm or so inside, you will see an allen key head screw. It is easier with a screw driver that takes an allen key drive as is very awkward to get a normal allen key down that deep. You will need to be in very good light or use a torch to look inbetween the seats as its very hard to spot. When you have removed the screws from both sides the pillion seat just lifts up and forward. The riders seat lift up and backward. Cheers
Jul 26, 2010 | 1996 Honda VT 600 C Shadow
Dont know how to fit the seat to the bike
1. Tighten the bolt on the seat-post of your bike's seat if your seat is a bit shaky. You may need to replace this bolt if it is rusted or withered.
2. Adjust the pitch angle of your seat if it is uncomfortable. You can have it level, leaning forward or leaning backward depending upon what is more comfortable for you. Use an Allen wrench (Allen key) to loosen the bolt on the-seat post to adjust the angle.
4. Tighten the tension on the cover of the seat if the seat has one and it is loose. If it has 2 straps underneath the seat attached with a hook, release it from the hook and tighten, then re-hook the straps.
May 15, 2010 | Dynacraft 16" Boy's Wheels Bike
Describe how to remove the seat of a yamaha r1 03
underneath the back left corners of the riders seat are the two allen head bolts that hold the seat secure. i believe they are 5mm allen heads but they might be 4mm. just kind of fold the corner of the seat back and you will see the bolts. be very careful when reinstalling the seat bolts, they are notorious for being cross threaded.
Oct 11, 2009 | 2003 Yamaha YZF-R1
How to take out/replace 2004 jetta seats (front and/or back)
For front seats. push them all the way to the front then got to the back and pop out the plastic covers on both sides of the tracks.
Then push the chair back and unscrew the nut under the seat in the middle on the end of the positioning guide you got to use an allen key. then you slide the chair all the way back and it will come out.
For the back seat use the same allen key and unscrew the 2 screws just below the front of the seats then lift the seat out. for the upper part just pull the two release knobs on each corner to drop it down. Then take a flat head screwdriver and push back the latch in the hinge of the seat at the side then it should pop out.
Jul 29, 2009 | 2004 Volkswagen Jetta
How do you remove the riders seat from a Yamaha
look under the back corners of the seat. I think there are two allen bolts there
Jun 15, 2009 | 2003 Yamaha Road Star Silverado
How do you remove the seat from honda goldwing 1997 gl1500??
You have Two Handles on the side of the seat... The allen bolts are in the handle... The bolts that hold the handle also hold the seat.... Remove all 4 bolt, Lift off seat from the rear. The front of the seat has a slide that goes in a grove
Apr 17, 2009 | 1997 Honda GL 1500 Aspencade Gold Wing
How to remove seat on 1999 gsxr 750
allen keys under ,rear corners of seat.Lift up to reveal !
Mar 04, 2009 | 1999 Suzuki GSX-R 750 X
Remove the seat
The two rear corners of the riders seat can be pulled back, you will find two allen head screws, simply remove them and the seat can be removed exposing the battery.
Nov 10, 2008 | 2008 Yamaha YZF-R6
Calligaris Ice Bar Stool CAL-CS-1050/P77_P266 Logo
108 people viewed this question
Top Calligaris Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Calligaris Furniture Expert? Answer questions, earn points and help others
