Question about Garden
Newholland tractor no drive fwd or rev
I had the same problem with my riobi lawn tractor .If you have hydro static drive the problem might be that your fan to cool tranny stopped working and overheated it causing it to burn out ,thats what happened to mine so check it out you never know.JL
Posted on May 13, 2014
2 Suggested Answers
  • 138 Answers
SOURCE: Craftsman hydro gear transaxle problem
check the brake for sticking and dragging. check the bypass lever, make sure it's disengaged fully. did you just fix a flat rear tire? if so, the square key that links the axle and wheel fell out. do you pull a heavy garden cart around? that can stretch a belt and overheat the trans. last thought, check the belt and see if it came off a pulley, i know that should have been first but it's late and i'm tired. good night
Posted on Aug 22, 2009
./model 917 273321 26hp hydro
well you need a new transmission for it. start looking on google or ebay. nobody here sells lawn tractor transmissions.
Aug 29, 2011 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
Jul 21, 2010 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
When I depress the forward drive pedal I move very slowly weather the deck is engaged or not. It is also very slow and sometimes stops in reverse. I usually have to use my foot and pull back on the...
You didn't specify a brand or type but it sounds like a hydrostatic drive model and if so, it is 1 of 4 likely things
Drive belt from engine to transaxle slipping badly (replace the belt)
FWD-REV pedal linkage faulty
Transaxle is broken or has fluid issues (not user fixable)
by-pass rod (neutral lever/rod) is pulled out a bit. (push it in fully!)
Jul 11, 2010 | Garden
Jd 05 i think 4310 wont move fwd or rev trouble code flashes four times one short ,long, short, short?
This is fault code 1.Fault-forward pedal.Cause of fault-Voltage signal out of range.Result of fault-Output current zero machine does not drive.Required action-get signal in range,,,recalibrate sensor.If this code does not match up to your symptom let me know and I will look into it.
Nov 19, 2009 | John Deere Garden
Need to change tranny oil in 550 deere is there a drain?
If it is four wheel drive then take the drain plug out of the fwd drop box.If not fwd the there is a plug in the lower part of the differential/rockshaft housing that you can remove.
Nov 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Aug 11, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
