Question about Tally T2250 Matrix Printer
Select company file dameged reason & solution
Hi i have received a message that my resume have been selected by Company HRD Info & i am unable to download the link 4 my offer letter www.sendspace.com/file/kzvmos plz help me for this. Or please...
plz help me for this. Or please reply me on my mail id shiprarocks20@gmail.com
Jul 29, 2011 | Measuring Tools & Sensors
New computer i need to down load deskjet 3650 printer, but when i try it says not in file, but it was \, i think i need a disk to install. my address is pete straus 147 taylor dr. logansport, la. 71049
The address below is a direct-link to the HP Drivers & Downloads site for your printer model. Simply select what version OS you're using on your computer and select the "Full Feature Software Driver" that is 16.34MB from the "Drivers" collapsable menu.
The package that is downloaded with used to install your printer, however, before doing so, make sure your printer is not connected to the computer via USB.
1. Double-click the driver package .exe file to open it. 2. Follow the prompts to complete the install. 3. When prompted to do so, connect the USB cable from your printer to the computer. 4. The installation will detect your printer automatically and finish the install.
If for some reason, the installation package does not allow you to install from your hard drive, you always have the option of burning the .exe file to CD/DVD, however, the files on the original manufacturer's CD are the same as those found in the .exe file downloaded, except that the CD's hold multiple language versions of the driver files and trial versions of specialty software from other 3rd-party companies.
Aug 10, 2010 | HP DeskJet 3650 InkJet Printer
I am getting error codes 6129,0 and 6073, 816 on my quickbooks 2008. What can I do to open the company?
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
Jun 01, 2010 | Intuit QuickBooks Pro 2008: Windows
Transfer vendor list from old company to new company in quickbooks 2005
Step 1 - Go to old company file, and select "File" then "Utilities" then "Export" then "Lists to IIF"
Step 2 - Select "Vendor List" then "OK"
Step 3 - Save to your desktop
Step 4 - Go to new company file, and select "File" then "Utilities" then "Import" then "IIF Files"
Step 5 - Select File from Desktop, then "OK"
Viola!
Dec 17, 2009 | Intuit QuickBooks: Pro 2005 for PC
Error message : File is damaged. Rewrite!
Step 1: Start Tally.
Step 2:
Step 3:
Tally asks to select the company to rewrite. Select the desired company to rewrite and then press Enter key.asking-tally-to-rewrite-a-company.png
Step 4:
Rewrite confirmation will be appeared on the screen, press "y" to start rewriting process.rewrite-confirmation-in-tally.png
Step 5:
After rewriting the data Tally creates Tally.rew file in Tally folder.open it in any text editor and go through it about the corrupted data.rew-file-in-tally.png
Sep 15, 2009 | Computers & Internet
Have a problem in tally 7.2
Dear Archana,
If you are using tally legal. Please check whether the date & time are correct. If correct then check the data folder file permission (readonly, hidden, system attributes) are removed. If not while starting tally press Ctrl + Alt + R for and select company which one is getting error. It will rewrites the data of that particular company. Then close tally and open again check it. If this doesn't work u should contact tally support with u r licence key and product id.
Thanks & Regards
Nanda Kishore
Nov 13, 2008 | Computers & Internet
Corruption of tally 7.2file
Exiting Tally!
File Damaged
File:C':Tally7.2\Data\009\manager.500
Size 180180
Position: 180352
Charj : 128 (done128)
Jul 04, 2008 | Tally T2250 Matrix Printer
Tally T2250 Matrix Printer Logo
13 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
