Question about Measuring Tools & Sensors
What metal is use to make bicycle gear cogs - Measuring Tools & Sensors
    Sergeant:
  • 258 Answers
Due to the heavy wear it is almost always steel.
Posted on May 13, 2014
Drive {pedel cog} just turns but will not drive the wheel cog
If a one speed coaster brake the rear hub needs to be overhauled. Take to a bike shop or bike co-op, unless you want to look up, study and follow carefully: Bicycle Coaster Brakes
Nov 14, 2016 | Cycling
Back wheel cog
the gear that needs to be replaced requires a special tool. You can get one online whereever you buy the gear you should also be able to purchase a splined socket to assist in getting the old one off of the hub. Might I suggest ebay.com?
May 11, 2013 | Mongoose 20-Inch Gravity Games BMX...
Nishiki bravo bicycle will not engage gears when pedalling
has the cog seperated or snapped off the wheel as in can you freeturn the wheel and make the cog go around or does the wheel spin but the cog doesnt move,
if so your up for a new rear wheel/cog
Jan 28, 2013 | Cycling
My mountain bike will not move from the 2nd front cog to the top cog (ie gears 13-18). i have adjusted the 2 screws which moves the chain guard across the 3 cogs but to no avail. also when in top gear on...
The problem lies in cable. Check out what make of front derailleur (cog shifter) you have (Shimano, SRAM, e.t.c.). Then visit the manufacturers website and check out for technical info and settings.
Jun 02, 2011 | Cycling
Chain slips on front cogs - half a turn on larger cog followed by half a turn on smaller cog - therefore unridable. The front cogs are warped ,moving left & right when being turned. I have got full...
I have straightened a large cog with a big screw driver, putting it through the outer part and levering against the inside. The metal of the cog bends quite easily and you need to work carefully, checking and correcting from the appropriate side as you go along. Your friends can stand and marvel at your brilliance, you don't need their help.
Mar 27, 2011 | Cycling
Good evening - I have Shimano Alivio Gears on my Cannondale F6 MTB and the gears are trying to change down a gear on the rear cogs (go to the larger cog) and need adjusting - which screw is the one to...
Neither screw is for mis-shifts. Those are limit screws for the largest and smallest cogs. Tweaking the cable tension will usually bring in the indexing...
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
It sounds like your cable is/was a smidge too tight.
Aug 14, 2010 | Mountain Shimano Alivio Front Bike...
I have a 1998 Gt Aggressor 26" bicycle. When shifting in the large gears, it hesitates before shifting or does not shift at all and just clicks. Can you help?
sound like the shift adjustment need moving or the cable to be adjusted from gear shift to the cogs there are a couple of ways to do this first select the low gear so the cable is slack and then look where the cable connects to the cog shift if you loosen the nust holding the cable and pull a little cable through retighten and try shifting.. if this doesnt work look at the way the guide moves the chain across if you see the guide stopping before the chain goes onto the cog look closely and you will see two small screws on the arm one is to stop the guide going to far to the right and one to the left look at the one on the right that shlould be the one for the transit to the large gear cog if you undo the screw half a turn then try the gear shift again see of it move far enough to put the chanin on the cog if not undo a little more.. these screws work for both the small and large cog shifting so the same can be done for the small cog if the chain keeps coming off.. Good Luck A
Aug 04, 2009 | GT Bicycles Cycling
Bicycle chain skips a cog
You may have a bent or worn gear on the rear. Take a good luck at the teeth on your gears -- if any are bent or worn down, replace the gear set. Also, does your derailleur need adjusting? THis will produce a chattering or scraping noise in soem gears. If it's not centering the chain over the gear in each gear, the sideways force can pull it off for a moment.
Jun 04, 2009 | Cycling
Front cog does not rotate when pedaled
You will have to remove the rear wheel and take it in to a bicycle shop and have the rear cog replaced. The freewheel part inside it has likely broken and will only rotate in both directions. It should rotate to back pedal and then catch as you pedal forward.
Apr 08, 2009 | Freestyle Cycling
Measuring Tools & Sensors Logo
27 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
