Question about Utilitech Pro 180-Degree 2-Head LED Motion-Activated Flood Light MST18
My liight comes on at dusk and stays on. I only want it for motion detection.
    Master:
  • 688 Answers
Read the instructions that came with your liight (sic).
Posted on May 13, 2014
  • Barbara Adams
    Barbara Adams Sep 09, 2014
    That was a jerky answer
I just installed a Utilitech dusk to dawn photocell this afternoon to control a pole lamp at the end of my driveway. We went through the wiring process several times to be sure that it was done according...
The sensor could be defective or the unit could be mounted in such a way that the transition to dusk cannot be detected. One other possibility is that the light has not been set for automatic operation.
May 25, 2017 | Hardware & Accessories
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
http://waterheatertimer.org/ST01C-program.html
Gene
h
Aug 18, 2013 | Electrical Supplies
How do i set the timer for a GE emp700ul-pc, cat#15147
F= off
O= on
1-9= # of hours it stays on after dusk
D= on from dusk to dawn
R= random hours is stays on after dusk each night
Dec 04, 2012 | GE 15107 24Hour Yard Stake Timer
How do I set the timer for a GE relocatable power tap EMP700UL-MT
F=off
O=on
1-9 = # of hours that it stays on after dusk
R= random amount of hours it stays on after dusk
Dec 04, 2011 | GE Home
I bought two motion sensing diecast lanterns model HB-4190 series, SKU 248-593 and the instructions are hard to understand. To make it easy tell me how to set the device if I want it to come on only if...
Hello Gerald. Each switch has a function. the the test-1-5-10 allows you to set it to test or an on period of 1 or 5 or 10 minutes. The off-3-6-dusk to dawn allows you to turn it off completely, operate from dusk for 3 hours, operate from dusk for 6 hours or operate from dusk to dawn. By operate I mean turn on and then stay on for the number of minutes you set it to with the other switch.
what's nice about the test setting is that with it allows you to check and b sure that the light will come on during daylight by setting the one switch to test and the otner to any setting but off.
If you leave the 2nd switch set to off the first switch will not allow you to test it.
Joe
May 22, 2011 | Garden
Can this light be set to only come on from dusk to dawn? This was installed by an electrician and he failed to leave the written instructions.
Yes,this light system is a motion sensor security light.Just turn the light switch on.When the sun goes completely down,somebodies or anamials go by the sensor covering area the light will go on.The sun rise the light will go off,will not go on.
Nov 24, 2010 | Heath Zenith All Metal Motion Sensor Light...
We have a outdoor light sensor and need to know how to keep it on sometimes while the children are outside playing at night. Now it comes on only during motion and then goes off in about 3 mintues.We want...
without knowing the model i can only suggest what works for the ones i have. one of them if you toggle switch on and off twice in 5 seconds it will be on full time, then toggle it on and off one to return back to motion. the other doesnt have that feature but there is a small switch on the top of the motion sensor to switch between dusk to dawn, motion, manual
Aug 20, 2010 | Garden
Hi I have a dusk to dawn motion light. It is the brushed nickel model. The problem I'm having is it is staying on all the time. The unit is only 4 months old. It was working at one time, then just quit....
Some of these fixtures have a function built in that turns the light on solid if the power is cycled rapidly several times. If you have had power glitches and this unit has that function, it might be locked on.
Pull the circuit breaker for the light for a couple minutes then try re-powering it to reset the function.
Jun 08, 2010 | Heath Zenith Journeyman 270 Degree Motion...
Dual Brite sensor lighting. Lights will not stay on even after human motion is in place sight of sensor during evening hours. I have the switches on dusk to dawn and the on-time switch is set to 20...
I really don't understand why these lights are so failure prone and I usually return at least 8 out of 10 back to the store but I've installed a lot of them. If its Zenith brand the light may need to be reset by turning the power off at the switch or breaker for 1-2 min then back on. Then check the motion sensitivity dial if its maxed out turn it back and set it to 75% full also the photo eye may be getting light from the light making it think its daytime at night so try to reaim the photo eye if possible away from the light source that should fix most problems or 20% of them but if you still have problems return it to the store or ask for their advise. Hope this helps I've seen a lot of junk motion lights in my time they are troublesome at times.
Jul 12, 2009 | Electronics - Others
Utilitech Pro 180-Degree 2-Head LED Motion-Activated Flood Light MST18 Logo
944 people viewed this question
Top Utilitech Pro Home Security Experts
Lawrence Oravetz
Are you an Utilitech Pro Home Security Expert? Answer questions, earn points and help others
