Question about Frigidaire Dryers
Error 67 gm
My dryer keeps turning itself on and making a beeping noise
    Master:
  • 697 Answers
It's hungry and wants clothes to digest. (Feed me, feed me!)
Posted on May 13, 2014
5 Suggested Answers
  • 641 Answers
SOURCE: Beeping dryer
You should open the service panel and to find out where does the "beeping" unit located and to remove one of the wires connected to it (the unplugged wire should be insulated). Good luck!
Posted on Sep 06, 2007
  • 44 Answers
SOURCE: Dryer doesn't want to run- makes grinding noise
its sounds like a worn bearing problem.with the m/c switch off ,turn drum by hand and see if it is hard to do so.if you get a gritty feeling in your hands or hear a grinding noise,then that is probably the bearing.
Posted on Jul 23, 2009
  • 553 Answers
SOURCE: My dryer panel is turning on by itself. when I
Many of your better dryers have an anti-wrinkle function. When a load is complete if you don't take care of it, every little while the dryer will turn on for a few minutes to fluff the clothes and beep to remind you.
Posted on May 31, 2010
SOURCE: Why does my dryer keep turning itself off before end of cycle?
If the dryer makes a motor growling noise at start up and shut off a short time later then it is probably a bad motor bushing and that will nessesitate a motor replacement. Bruce
Posted on Sep 27, 2012
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
I have a ge profile refrigerator and it works fen except it ekes buzzing. The ice lock/lock function, no body is pressing the button but it keeps locking and unlocking itself and the buzzing/beeping i
The switch that does the lock/unlock has got wet inside.
Make sure you can see the back panel of the switch and use a hair dryer to warm the panel back and the front of the switch. When it gets warmer it may dry out and start working normally.
Dec 21, 2013 | GE Refrigerators
Sep 27, 2012 | Dryers
My dryer panel is turning on by itself. when I shut it off, it turns back on after a while. A load of clothes is drying, and the dryer keeps making a beeping sound every now and again. It seems to be...
May 31, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool Electric Duet Sport Dryer
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Fuse
NO YOU HAVE A VENT HOSE RESTRICTION,YOU MUST CLEAN OUT THE DRYER SIDE AND THE WALL SIDE,USE A LEAF BLOWER FOR THE WALL AND A SHOP VAC FOR THE DRYER,UNPLUG DRYER WAIT A FEW MINUTES AND SEE IF IT RESETS ITSELF,MIKE
Sep 04, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
Ok , I replaced the control board. Still beeps continuously. Just sitting there, nothing else is on, just plugged in......beeep,beeeep,beeeeep,WTF man? I am about to turn this damn thing into an anchor and invest in more clothes lines! Maytag sucks. MAYTAG an acronym for...
Maybe
All
Your
Technicians
Agree;
Garbage...
May 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Beeping Dryer!
Hi, the the glowing igniter does not functioning need to replace / the sensor tip will send signal to computer box that the glowing are busted.
Jan 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Jul 16, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
26 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
