Question about Marantz Audio Players & Recorders
How do I get my Ipod to register and play on my Marantz NR1603?
When I plug my Ipod touch or just normal ipod with the circle dial into my marantz in the front port on the ipod mode, all it says is "Please wait..." with no reponce. Anything I'm doing wrong and how do I go about getting the amp to read the ipod?
    Genius:
  • 1,175 Answers
Does the cable work OK on other equipment?
Do you have a manual for the Marantz ?...If not , try their website
Posted on May 27, 2014
techman
  • 3130 Answers
SOURCE: Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Posted on Aug 26, 2006
cyrylthewolf
  • 143 Answers
SOURCE: Problem with Marantz SR5500 Receiver
Sounds like you have an issue with your electrical circuit. Your receiver could be receiving spikes of current from the electrical wiring in your house.
Review your current electrical situation. Keep in mind that certain outlets are on the same circuit and that running multiple, high-wattage devices on the same circuit can cause issues with some of those devices. Especially when it comes to turning devices on and off.
Many devices take a sudden, rapid charge to power their circuitry the moment you turn the device on. Home audio and HVAC systems are particularly notorious for doing this. Other devices on the same circuit can sometimes suffer influxes of power flow and may either turn off or go into standby mode to protect themselves from the resulting surges.
I've lost audio systems that way... I lived in an apartment building that has wiring most likely dating back into the 40's. I once turned on a space heater on it's max 1500 watt setting and blew my Logitech Z-680 speakers. (The "BOOM" sound that emitted from my subwoofer was AMAZING. I had just blown an amp circuit. It literally exploded inside of the subwoofer. Took pics and everything.)
If you have the means to do so... You might consider re-wiring your electrical circuit. Take into consideration where you're going to run certain devices and wire the system accordingly.
In the meantime, you would want to be sure to buy a HIGH-QUALITY surge protector for the audio system. Spend a few bucks and get a GOOD one with a good warranty on it. Don't use those cheapy ones that we only really use to split the outlet. NOTHING under 1,000 joules.
My receiver sometimes locks itself like that, though. If we have a power outage or the unit is unplugged suddenly, it will keep itself in standby mode until you unplug it, press the power button a few times to discharge any current left in the capacitors and plug it back in normally. Only then will it turn on again.
Let me know what you come up with.
Cyryl
Posted on Nov 03, 2007
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
  • 4 Answers
SOURCE: Marantz 6200
Your unit's micro IC, is in need of a reset.Un-plug the unit and locate the semi large yellow capactor on the main board. (r-h side facing front) Now flip the unit over and look thru the vent holes in that same area and locate the two solder pins. Short them out with a thin metal object, like a straightened out paper clip or wire, and turn it over (just discharge the cap and remove your wire) this will default all settings and restore normal operation.
Posted on May 27, 2009
  • 133 Answers
SOURCE: marantz sr5001 has pcm light flashing
I suppose pcm light means that the pcm mode is turned on (pcm meaning pulse code modulation), in other words, the unit was switched to digital signal, so if the digital rca or optical TV input on your reciever is not connected to anything, then you're not getting any signal into the reciever in digital mode. You probably just need to switch the unit back to analog mode (see if there is a button that says something like digital/analog, pcm/analog, optical/coax or similar, try pressing it, see if there is any change).
I might just be totally wrong on this, however, probably the best way to learn what happened is to read the user manual if you do have it (see what the pcm light signals for and check any chapters inside the manual related to that topic).
good luck
3rq8 (Triarcuate)
Posted on Jul 25, 2009
Marantz 1170 was playing music and started turning up volume all music shut off what's the problem
how old is that unit ?
cant find a picture of a 1170
faulty volume dials or slides
internal fuse ?
power source over heating
just how load = enough to pop the speakers
Apr 16, 2017 | Marantz Audio Players & Recorders
How to connect a marantz 6005 amplifier to an ipod
Is it an SR6005?
If so , make sure you have a cable that converts your Ipod output to 2 RCA ( phono) style connector plugs and use the AUX input on your receiver.
May 26, 2014 | Audio Players & Recorders
I want to connect an iPod to my Marantz SR 5600, what type of cord do I need?
You need a jack-2cinch (differen name is jack to 2 RCA) cable. Jack goes to your iPod's phones output, cinch/RCA to amplifier (connect it to CD or DVD analog section at the back). While playing set volume to 50% to avoid distorted sound. This way you can connect any MP3 player to your amplifier.
May 08, 2011 | Marantz Audio Players & Recorders
The songs are on repeat - will not go to next song on the list...the ipod is 2 days old !!!!!!
Step 1: Go to Music, and then select any song to play.
Step 2: You should now be at a screen with the album art and play controls on the bottom. Tap the screen and you will see little icons near the top where the timer is.
Step 3: Tap the icon with the circle arrow until it is no longer highlighted in blue. Your iPod should now be playing normally.
Dec 29, 2010 | Apple iPod touch
How do i connect my ipod to my marantz PM7200
As dunnbiker said, get a headphone to RCA adapter. After that you may find that you still need a bit more gain out of your ipod. There are lots of solutions. Google preamp or check out Sound Shocker by PHP Audio.
Nov 29, 2009 | Marantz PM7200 2-Channel Amplifier
Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
Jul 05, 2008 | Marantz SR-5200 Receiver
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
