Any help with arithmetic expression? - Office Equipment & Supplies
How to do a binomial problem on a ti-73 scientific calulator
Terminology: Sorry I see no binomials in your expression. All you have is a sequence of arithmetic operations. That amounts to a monomial of degree 0 (namely a constant term).
Enter your expression on the calculator as you typed it in your question. BTW, you could save yourself a lot of stress by simplifying expressions. They will look doable by hand.
16*1/2=8
1-1/2=1/2
(1-1/2)*16=8
All that is left is
8*6*8-5*8=(48-5)*8=43*8=320+24=344
Apr 15, 2014 | Texas Instruments TI-73 Explorer...
How do you use the calculator to solve aRITHMETIC AND GEOMETRIC SERIES
http://www.ticalc.org/pub/83plus/basic/math/series/ Check out the first file on the page, it should be a program to do it
May 17, 2011 | Texas Instruments TI-83 Plus Calculator
Hi, I have a Casio fx-115s scientific calculator which I've had for around 25 years. I am unable to use the bracket function and have lost the instructions. Could you please give any advice to save me...
You should be able to use parentheses in the same order in which you would write the arithmetic expression. For example, 4*(3.5-1.5)= should give you 8. Without the parentheses, this would 12.5.
Essentially, the left parenthesis comes immediately after an arithmetic operator, and the right parenthesis must close the parenthetical expression right after a number, and an operator must follow the right parenthesis.
Apr 23, 2011 | Vacuums
My fx_115ES casio is displaying Dec and I don't know why!
You're in BASE-N mode for integer arithmetic. Press MODE 1 to get to COMP mode for real arithmetic or MODE 2 for CMPLX mode for complex arithmetic.
Apr 04, 2011 | Casio FX-115ES Scientific Calculator
How to do modulo operation in casio fx991ms
The fx-115ES does not have a modulo operator. However, it is possible to compute the remainder using integer arithmetic. Press MODE 4 to shift into integer mode. Then calculate A modulo B as
A - B * (A / B). For example, to calculate 41 modulo 6, press
4 1 - 6 * ( 4 1 / 6 ) =
and get 5.
Press MODE 1 to return to real arithmetic.
Feb 07, 2011 | Casio FX-115ES Scientific Calculator
Not reading correct gb
What is it reading?
Note that 74.5 times 1024 times 1024 times 1024 divided by 1000 divided by 1000 divided by 1000 is 80.
So, if you use base-ten arithmetic, you have an 80Gb disk,
but if you use base-two arithmetic, you have a 74.5GB disk.
Nov 17, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Explain 1 divided by 0
In mathematics, a division is called a division by zero if the divisor is zero. Such a division can be formally expressed as a / 0 where a is the dividend. Whether this expression can be assigned a well-defined value depends upon the mathematical setting. In ordinary (real number) arithmetic, the expression has no meaning, as there is no number which, multiplied by 0, gives a (a?0).
In computer programming, an attempt to divide by zero may, depending on the programming language, generate an error message or may result in a special not-a-number value (see below).
Historically, one of the earliest recorded references to the mathematical impossibility of assigning a value to a / 0 is contained in George Berkeley's criticism of infinitesimal calculus in The Analyst; see Ghosts of departed quantities.
Sep 03, 2010 | Computers & Internet
4_4_4_4=20
If you're using base-10 arithmetic, compute: (((4/4)+4)*4)-20
If you're using base-8 arithmetic,
compute: 4+4+4+4 - (2*8**1+0*8**0)
Aug 17, 2010 | Computers & Internet
What are the heirarchy of operation?
The following information on "Hierarchy of Operations" was taken from Pages 45-46 of the "Microsoft QuickBasic 4.0: Basic Language Reference" manual for Versions 4.00 and 4.00b. This information also applies to the following products:
  1. Microsoft GW-Basic Versions 3.20, 3.22, and 3.23
  2. QuickBasic Versions 1.00, 1.01, 1.02, 2.00, 2.01, 3.00, 4.00, 4.00b, and 4.50
  3. Microsoft Basic Compiler Versions 5.35, 5.36, 6.00, and 6.00b
  4. Microsoft Basic PDS Version 7.00.
MORE INFORMATION The Basic operators have an order of precedence, that is, when several operation... loadTOCNode(1, 'moreinformation'); The Basic operators have an order of precedence, that is, when several operations take place within the same program statement (without being grouped by parentheses), some operations are executed before others. Operations are executed in the following order:
  1. Arithmetic operations
    1. Exponential (^)
    2. Negation (-)
    3. Multiplication and division (*, /)
    4. Integer division (\)
    5. Modula arithmetic (MOD)
    6. Addition and subtraction (+, -)
  2. Relational operations (=, >, <, <>, <=, >=)
  3. Logical operations
    1. NOT
    2. AND
    3. OR
    4. XOR
    5. EQV
    6. IMP
An exception to the order of operations listed above occurs when an expression has adjacent exponentiation and negation operators. In this case, the negation is done first. For example, the following statement prints the value .0625 (equivalent to 4^-2), not -16 (equivalent to -(4^2)): PRINT 4 ^ -2 If operators on the same precedence level appear in the same expression, they are computed from left to right.
For more information on the "Hierarchy of Operations," consult the Basic language reference manual for your version of Basic. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 13, 2010 | Microsoft Windows XP Professional
Lost CALCULATOR application
  • Scientific
  • Statistical
  • Financial
  • Programmable
  • Graphing
  • Complex arithmetic
  • Matrix/vector arithmetic
  • Unit arithmetic
  • RPN
Download You can download Calc into your phone or MIDP device using one of these links:
Calculator 1
http://midp-calc.sf.net/Calc.jad, or
http://midp-calc.sf.net/Calc.jar
click her for calculator 2
transfer both the files to your mobile and then install them by just clicking on open install
Mar 31, 2010 | Nokia 5220 XpressMusic Cellular Phone
k24674
