Question about Samsung DVD-R155
HCT DVD recorder: HDVR-960s
When I do an auto channel scan, and it does not matter whether I choose "Air" or "Cable" two out of the 10 Channels it finds are displayed in Black and White but, with a very clear picture. The RF coax pass-thru to the TV the same two channels display in color. What is going on with the DVD Recorder ?
  • Anonymous Jan 16, 2008
    I've had similar problems. First five channels have degraded picture even after fine tuning. Exchanged the unit with another unit; same problem. I also know someone that purcahsed a HCT TV and it had problems with channel scanning.
  • sgtken May 11, 2010
    I have a new HCT HDVR-960S. It is the unit with a built in 250GB hard drive.
    I turned it on yesterday, and now all I see is a half-black and half-white screen when I try to play a dvd or anything stored on the hard drive.
    Any feedback as to how to get this thing back to normal appreciated...Ken in Chitown
Regarding the Black and white lines
You need to click menu scroll over to the right and select reset to factory settings.
I know you can not read the screen so try and follow the steps below.
After fixing mine by carefully reading the screens I went back and retraced the steps and counted.
Follow these directions. Do not go too fast or you may miss or lock up.
Turn the machine on.
Then with the remote
1). Click the button Settings
2). With the right arrow (blue directionals) click 5 times slowly. Slowly.
3). Click Enter button
4). With the down arrow (blue directionals) click it 2 times.
5). Click Enter button
This hopefully Resets your machine back to Factory settings.
It worked for me.
Posted on Oct 04, 2008
I purchased this same unit yesterday from the PX Power Zone. I hooked up the unit and even managed to record a few minutes of a show. I then went into setup and made a few changes. Now, I have no display at all from the unit. Does anyone know how to reset the unit back to factory settings? Please email me at Many thanks!
Posted on Aug 10, 2008
Auto scan can only find one channel. I am on comcast cable and I have clicked the correct set up
Auto scan is to find ON AIR channels not cable channels. Probably only one in your area is strong enough OR you don't have an antenna attached (more likely)
Jan 20, 2018 | Comcast Televison & Video
How can i get the channel auto scan on my Hisense 55h6sg tv to find any channels.
If it is asking for zip code you have not told it to scan for over the air or antenna channels when it asks air or cable
Dec 12, 2016 | Hisense Televison & Video
How do I run a channel auto scan?
There are many different ways, because each TV manufacturer calls each menu option something different. In your TV menu there should be an option that says Set Up, or Channels, or something similar. Your TV should be, Menu, pan right to Channel, select whether you are using Air (air meaning antenna, picking up channels that are broadcast free over the air) or Cable (only if you use cable with no box). Then the option below should be auto scan. Allow to run completely. Sanyo DP42D24 User Manual Channel
Apr 06, 2015 | Sanyo DP55D44 55" 1080p 60Hz LED HDTV
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
Apr 08, 2014 | Televison & Video
We can't get any of the channels don't know where to start from menu area
You just do autotune to receive all channels. In this mode TV will tune through the entire channel band automatically, and finally will stop tuneing, and will show the first channel receved. You must be patient for these time. about two or three minutes, without disturbing is process. The tuning process follows.
Auto Tuner Setup
In Auto Tuner Setup, the TV automatically scans
t h rough all available channels, memorizing the active
ones and skipping over blank ones or channels with
weak signals. This means when you scan (using the
CH A N N E L +/- b u t t o n s ) you will receive only clear,
active channels
P ress the ME N U b u t t o n
Press Right or Left button to operate
Press Vol+ or Vol (--) to choose CABLE or AIR
Press UP or DOWN button to move to START
Press Right or Left Button to start Auto Tuner Setup
Tv will show "NOW PROGAMMING" display.
Programming will take approximately 1 to 2 minutes.
After all it will show
Some cable systems experience interference from radio frequencies on cable Channel 95. You may delete this channel from
your scan by removing the "X" next to it on the Channel Summary screen.
Nov 29, 2010 | JVC AV-27120 27" TV
There is no local channel,cable only international..i lost my manual,
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
You need to use the setup menu to specify the tuning band (specify whether you have cable or an over the air antenna) before doing an auto channel scan.
Dec 01, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
I just got cable and I cant get the channels to come in as cable channels. I lost my manual and have a universal remote?
Hi gail dahl,
I am happy to help.
From the Video Menu the Tuning Band must be set to Cable and not to AIR or Antenna. You will nee to run Auto Scan for channels from the Menu also.
I have provided a link to download the manual.
Let me know if you need further assistance and please rate this solution. FixYa.
Jan 31, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Your problems can be solved by using the menu setup on your tv. Spanish is an option you can choose.Also on the menu you select air(antenna) or cable,then choose auto scan.The tv will pick up all channels available in you area.
Dec 20, 2008 | RCA BD20TF10 20 in. TV/DVD Combo
Samsung DVD-R155 Logo
654 people viewed this question
Jerry Greenberg
Jerry Greenberg
