Question about Toys
Freightliner troubleshooting has all new abs sensor replace,,,
    Master:
  • 697 Answers
Now, this post is under the heading "Dolls, Playsets &Toy Figures", so if "abs" refers to your abdominals, I have no idea....
Posted on May 13, 2014
Will a 2002 freightliner century classic hood fit a 2003 freightliner century classic
Better ask Freightliner.
Freightliner CENTURY CLASS 120 Hood Parts ' TPI
truckpartsinventory.com > Hoods > Freightliner
Freightliner Century Class C120 BBC Fiberglass Hood Shell. Fits Models from 1997-2002 with Old.. ... Shell (Economy). Fits 2002 - 2004 Models with New.
Search Results Freightliner CENTURY CLASS 120 Hood on ...
https://www.heavytruckparts.net/search.php?...FREIGHTLINER...CENT...
Active Truck Parts Hood FREIGHTLINER CENTURY CLASS 120. More Info ... HoodFREIGHTLINER CST120 CENTURY, 2002, 1FUJBBCG92LJ79765, Hood
Oct 30, 2015 | Cars & Trucks
ABS LIGHT IS ON ALL THE TIME
I've had that problem too even changed the abs switch, the best thing to do is put duct tape over the switch on ur wheel
Feb 11, 2015 | Freightliner Columbia & Century Class 120...
Abs light is on all the time sometimes I get a code
Abs sensor will need replacing, cleaning them won't help, you need a code reader to see which one needs replacing then you need the code reader to delete the fault code
2015 freightliner cascadia with abs 11 code and abs light always illuminated.
As it is still under warranty I suggest that you find a service dealer and let them fix the problem. As it is a heavy vehicle I suspect that a sensor wire at a wheel hub may be disconnected or broken off
Feb 03, 2015 | Cars & Trucks
How do i troubleshoot 2007 freightliner century sleeper blower motor?
possibly the resistor that controls the speed has gone look near the motor .
Oct 04, 2014 | RTO Ho Herpa Freightliner Truck Tractor
2010 freightliner cascadia with abs code SAE 254
the abs light is on, it telling you that there have a problem on your abs system, such as simple wiring issue with a sensor, or it could be as bad as an abs module. it need to be plugged into a OBD2 code scanner/reader to know exactly what part triggered the code.
Aug 08, 2012 | Dodge Cars & Trucks
I got the ABS Light on my 2005 Chrysler Town and
Stop at a Tuffy or other shop and they can scan for codes to tell you which sensor may be faulty. Wheel sensors are easy to replace.
Apr 09, 2010 | 2005 Chrysler Town & Country
Active faults 1 at startup screen
if you press and hold the mode button it should beep then you will get the component location. ecu 128 for example is in the engine- mid 136 is the abs. once you see that, press the mode button again and you will get the code. sid 123 for example- press mode button again and you will get the failure code. FL 02, could indicate when it is reading a high or low reading, short or open... etc. once you have the three parts of this code then you should be able to contact your local dealer to find out what the code means. Truck diagnostics are not always easy... active codes really just give technicians a place to start... hope this helps
Dec 16, 2009 | RTO Ho Herpa Freightliner Truck Tractor
Toys Logo
81 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
