Epson sx440 how heavy a paper can it take, Mine won't take the epson 192g matte archival
SOURCE: Epson R1800 refuses fine art papers
Hi Fruitless, Last night I was tearing my hair out trying to get my R1800 to accept some Hahnemuhle Satin 310, and it was just passing through and passing through. About once in 20 trys it would finally print. I was in the middle of making up my own paper profiles for this lovely paper. Anyway, I gave up at about 1:30 am, and went to bed. Today I resumed my attack, and guess what fella, there is a solution. Pass this on to everyone. You did not say what version of Photo Shop you were using. I just got my CS3 a week ago, and if you are using it, you can open a photo for printing. Go to Printing Preferences Dialog Box, > click on Maintenance Tab, and then click on the Bottom button that is labeled as Printer & Options Information. The Printer and Options Dialog Box opens, and there at the bottom is a box that says Thick Paper right beside it. Select or check this box and enjoy yourself thereafter. I did not see this in the User's Guide, but knew there had to be an answer to this problem somewhere. No problems ever since. Best of luck.
Posted on Sep 25, 2007
Inky
  • 691 Answers
SOURCE: printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Posted on Nov 09, 2008
SOURCE: epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller: http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf I used the paper towel method and it's working fine now with no issues.
Posted on Mar 06, 2009
SOURCE: Epson 10,000 won't print on posterboard
Prints on 44" Wide paper up to 1.5mm thick
Does this help at all?
Posted on May 29, 2009
SOURCE: epson artisan 800 wont print to a transparency
OK so i tricked my 810 into printing on a transparency. NOT that I recommend doing this ... but .... I took four pieces of clear tape and taped the top (where it goes into the printer) and on each side about three inches from the top.
Then I put it in the tray with the transparency on the bottom of the paper -- since it brings it up thru the printer and flips it over, it prints right onto the transparency !!!
It didn't like it the first time, since I just folded over the tape on the end that gets sucked into the printer first. Hence the added stabilizers on each side.
Posted on Mar 01, 2010
I have a Epson pro large format 9600, I print on canvas, I have use Photo black since I have it, but never getting a saturation ressult. I have been counsil by Epson to use Matt black rather than Phot
"Photo black" is designed specifically for glossy photo paper. Matte black is for non-glossy paper, including plain paper. Matte black will print darker on non-glossy paper than photo black does.
Oct 28, 2014 | Epson Office Equipment & Supplies
The paper feed is not working properly - either does not pick up first sheet or feeds it in out of alignment (crooked)
You have to clean the two pickup wheels with some stickey paper. ie the cleaning paper that comes with epson archival matte paper. Out of a lot of them I make my own with two sticky stibes on. Run then several times. Then it work. When you are done. stop using the paper you are using. I stopped using Tetenal because it had some very fine white stuff on that made this problem.
Oct 08, 2009 | Epson Stylus Pro 4800 InkJet Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
May 29, 2009 | Epson Stylus Pro 10000 InkJet Printer
Printing heavy weight invitation stock on Epson R200
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Black ink mark
try this......run a card with heavy matte paper using 'regular settings'.....see if the extra black is gone then
Oct 04, 2008 | Epson Printer
Epson C120/ Stops at Perforated line
the sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Bright White Paper
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Paper Glossy
Epson Photo Quality Self-adhesive Sheets
Epson Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-sided
Epson Presentation Paper Matte
Epson Ultra Premium Photo Paper Glossy
Jan 23, 2008 | Epson Stylus C60 InkJet Printer
EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
See your printer documentation.
Nov 08, 2007 | Epson Stylus Photo R320 InkJet Printer
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Aug 15, 2007 | Epson Stylus Photo R1800 InkJet Printer
24 people viewed this question
k24674
