Emachine problem T3312 desktop stopped working after a lightning storm. No display. When I apply power the power button on front flashes slowly and I hear a pulsing sound on the speaker (like a heart beat). Any ideas how to revive the patient?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Unfortunately your patient is dead. The power surge has almost certainly burnt out one or more connections on your motherboard. The power supply is still functioning as you have a light on, but the only solution is a new motherboard. It's also probable that your memory has been trashed, and the only way to tell if the hard drive is still OK is to try it in a working PC. Power surge protection sockets are very cheap and it's worth plugging your new PC into the mains via that next time :)
Posted on May 13, 2014
SYSTEM ONE
  • 85 Answers
SOURCE: I'm having problems starting my
When you say you hear the computer working and working do you mean that the fans are going and the lights are on?
i ask this because the fans and power lights can come on just from the power supply coming on when you push power but that doesn’t necessarily mean the cpu is functioning.
Do you hear a post system beep and the hard drive reading files also?
Or does it just sound like only the fans cam on ?
If you think that possibly only the fans are working then try this
Shut down the computer and unplug the power cable.
Check to make sure monitor cable is connected all the way
Open the case and check to see that the video card is inserted all the way into the board properly
Remove the memory (RAM) and then put it back in to make sure it is properly seated in the slots
Plug in computer and try it again and if it still does not work then try clearing CMOS
on some systems you can clear the CMOS very easily by just holding down the insert key on your keyboard while pressing power button and continue to hold it down when releasing power button until you see something on the screen but since this does not work on all computers you might have to do it manually by moving the CMOS jumper on the board
(the CMOS jumper on the motherboard is usually the one closest to the little battery that you see on the board. with the computer off move the jumper over one notch to the other pin for a second and then put it back where it was (there are usually only three pins so this is easy step)
You should now be able to boot but you will need to go into the CMOS setup and set the clock again and other settings
If you still have a blank screen then let me know and i will take you to the next diagnostic step...
Hope this info helps
Posted on Nov 20, 2008
jell587
  • 447 Answers
SOURCE: No Sound on Emachine T5048
Download the Realtek HD driver from here, re-install. Should fix the issue.
Posted on Feb 20, 2009
  • 916 Answers
SOURCE: HP dc5000 won't start. Green light on front is dim and flashing.
Hold down the power button until the machine completely turns off. Then turn the machine back on and let me know what happens.
Posted on May 26, 2009
bob_computer
  • 3153 Answers
SOURCE: emachines 180 desktop sound problems
Plug in ONLY the regular wired speakers and ONLY to the green port on the back.
Make sure they are powered up and the volume is about half way.
Ok now you need to call up ether the sound card application or preferably the windows volume control from the bottom toolbar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in
are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else)
Now close the slider box.
Put a normal music cd in your cd/dvd player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
Double check that EVERYTHING is ok.
If there is still no sound check the control panle for any hardware issues and rectify those
Posted on Sep 21, 2009
sparky1500
  • 1066 Answers
SOURCE: when you turn on my emachines desktop it comes on,...
you prolly need a new video card.
Posted on May 24, 2010
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
Dell 4600 won't power up following lightning storm. PSU and power button both test OK. Suggestions please! many thanks
Check everything between the power supply and the wall outlet. If everything else is working using the same power a part of your computer is fried.
Jul 27, 2011 | Dell Dimension 4600 PC Desktop
Need to reinstall
you can either use a recovery disc if you made one, and the drivers can be found like this, go to google and type in emachines, go to the emachine main page and there should be a support section, go there and there should be a option for drivers, it will ask you to tell them what kind of computer and use that number t3312 and it should show you all the drivers, plz understand if you install a OS all ur data on your hard drive will be erased so make sure you have the drivers on a flash drive or cd so you can install the drivers without internet connection just in case it wont allow you due to the drivers
Feb 10, 2010 | Computers & Internet
My emachines EL 1200 desktop stopped working during bad storm
You can try to reset the computer by removing all power sources and letting it sit for a time. Then powering it back up and see what happens. That's called a hard reset.
I am guessing that the storm surge damaged your motherboard. The power supply is working or nothing would work. Try to hit the proper F key and get into the set up on the motherboard. A message should come up when you start up the computer. This is to see if your motherboard is working enough to open the set up. You can then tell it to reset to bois to factory settings.
If none of that will work, I suspect *********** board is bad and needs to be replaced.
I am sorry I don't have more positive information for you. But I hope that this will get you on the right track to solving your problem. Remember, this is only an educated guess. If you do find this helpful, please leave positive feedback for me.
Thank You,
Brian
Jan 25, 2010 | Computers & Internet
61" Mitsubishi Proj...stopped working after lightning storm
resetting set will not help, don't know which model you have but problem is most likely on dm board.
Aug 22, 2009 | Televison & Video
Lightning Storm/Affinity Washer
During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
Jul 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
I need a mother board for my T3312 model. Where can I go on the internet to purchase one
here you can check out this link for the parts you requested http://parts.emachines.com/Moreinfo.asp?Product_Id=69279 how ever did you diagnose the problem correctly to know that the motherboard is dead or it is the power supply or something you failed to connect properly for instance all the power cables that the motherboard needs to supply power to its components
May 24, 2008 | E-Machines Computers & Internet
Laptop Won't power up :(
remove battery pack and cleaned battery terminal
Mar 06, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
