Question about Intermatic Hardware & Accessories
Intermatic master control
How do i use it
  • Intermatic Master
  • 5,245 Answers
Copy following links to help identify timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
Add comment and describe timer or controller
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on May 13, 2014
Where are the fuses located?
http://waterheatertimer.org/Intermatic-control-centers-and-manuals.html
http://waterheatertimer.org/How-to-wire-Intermatic-control-centers.html
Open door on control center, and push breakers fully off and then fully on
Use manual override lever located on each timer to see if pump can be manually operated
Gene
Sep 01, 2014 | Intermatic T40004R - Pool-Spa Control...
How do i set my intermatic master control II model ed811
ED811 is older analog timer for turning table lamps on-off.
Copy following link for setting analog timers.
http://waterheatertimer.org/How-toset-timers.html
If dial does not rotate once each 24 hours, then timer motor has gone bad, replace with new analog timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TN
Add comment and say what you discover
Apr 26, 2013 | Intermatic Hardware & Accessories
Show a video of setting up everything
Which timer do you have? What voltage are you using? What are you controlling?
Copy following links for Intermatic T101 120Volt timer
Reading required.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
More related images, showing 240Volt Intermatic:
http://waterheatertimer.org/Photos-of-WH40-timer.html
Video of this information might be available, but resources above are more complete, more detail, and tested certain.
After you master the timer, make a video, post on internet with up-close in-focus images, and then add comment with link to your video.
Mar 16, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
I need a manual for wired in timer by time master
1) Time master is sometimes the same as Intermatic EJ351:
Copy following link to identify timer:
2) Add comment and describe timer in detail, and/or include photo of timer so expert can identify timer.
Dec 13, 2012 | Hardware & Accessories
Manual for intermatic timer part no. 2T511GA
2T511GA is an Intermatic enclosure (or box)
2T511GA is a grey standard Indoor/Outdoor Nema3R metal enclosure.
http://waterheatertimer.org/pdf/Intermatic-Enclosures.pdf
Any intermatic box timer will fit into the enclosure.
Tork makes the IAP adapter so Tork/ GE timers will also fit into same enclosure.
This includes digital timer and analog timers made by both companies.
To find the exact manual, add a comment and describe the timer and number of terminals, and what voltage is being used, and what you are controlling with the timer. For example 6 screw terminals A 1 2 3 4 and controlling 2-speed 240 pool pump. etc.
Also copy following link to identify timer and download manual:
Aug 16, 2012 | Intermatic Hardware & Accessories
I want to replace a Paragon 4004 20M with a Intermatic T104M. The Paragon has 4 screws along the bottom and one more on each side higher up for a total of six. The Intermatic has six, plus the ground. ...
1) These timers are interchangeable.
2) These timers can be complicated. Both handle multiple voltages and can be wired many ways depending on load requirement, wire from breaker box.
3) Description of Load(s), voltage(s) and wiring is not described in question. Add a comment with specific information for detailed help.
4) The 4004-20 timer has wiring terminals 1 2 3 4, plus terminals 5 and 6 that are connected with a brass bridge to terminals 1 and 4.
Since the terminals are connected with brass bridge, terminals 5 and 6 can be considered same as terminals 1 and 2.
If the brass bridge is removed, then the timer can be wired many ways to control multiple voltages, and then terminals 5 and 6 are independent.
5) Intermatic T104 timer has terminals A 1 2 3 4
Intermatic T104 terminal A is not used except as a bare post for Neutral wire, and if timer is wired to control 277V or 440Volts. Or if timer is adapted in other manner.
6) When controlling ordinary 2-wire 240Volt load like a pool pump, here is crossover wiring.
Paragon terminal 1and5-bridged goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminal 3 goes to Intermatic terminal 4
Paragon terminal 4and6-bridged goes to Intermatic terminal 3
Intermatic terminal A is not used in this case.
Sep 13, 2011 | Intermatic T104M 208-277Volt 40-amp Timer...
I can't download the instruction manual from Intermatic's website. I have a EJ500C timer and want to know why they caution against using it with CFL's and how to program it to shut off...
EJ500 7-day or astronomic timer is incandescent light bulb timer.
Different timers have different Load ratings.
Intermatic ST01C timer can control CFLs.
Aube timers have same wiring capability as Intermatic, and offer CLF control, but you have to choose either astronomic timer, or 7-day timer.
Open following links for manual and timer information.
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
http://waterheatertimer.org/Aube-timers.html
Jul 16, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
Can you fit a frost switch to the T10404R
http://www.poolandspacontrols.com/~/media/Files/PoolAndSpaControls/Products/Instructions/PF1102.ashx
http://www.poolandspacontrols.com/products/freeze%20protection%20controls/multi%20circuit%20freeze%20protection%20controls.aspx
Intermatic makes a freeze protection control that wires directly into a 240V timer.
If you already have a freeze control, the wiring diagram might help.
The manual has this image larger.
It shows wiring to connect the freeze control directly to one 240V timer.
Intermatic make a freeze control for 1 or 2 circuits.
Intermatic page showing Pool and Spa timers
http://www.poolandspacontrols.com/products/mechanical%20controls/100%20amp%20specialty%20control%20panels.aspx
Nov 11, 2010 | Intermatic T10404R - Two 220 time clocks...
Mx-600 master remote
forgot how to program the learning remote feature
Sep 11, 2007 | Intermatic HA07C Remote Control
Hardware & Accessories Logo
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
