Question about MotorGuide Electrical Supplies
Why does my motor guide 50 trolling motor fuse
Everytime I run my trolling motor on 5 it trips the ciruit breaker 40amp, it then needs to be reset. Works great on lower speeds. Do I need a 50 amp?
    New Friend:
    Problem Solver:
  • 7 Answers
It depends on how much current the trolling motor is supposed to draw when set to 5. If it's more than 40 amps, then you need a larger breaker. If it isn't more than 40 amps, then your current 40 amp breaker is weak and needs to be replaced.
Posted on May 16, 2014
  • Roland Leal
    Roland Leal May 16, 2014
    Thanks for the suggestion. Additional info It must only trip when in water pulling a load. ,it runs on 5 when just testing on land.
tjt3
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
protek480
  • 1723 Answers
SOURCE: 50 amp GFCI breaker trips after spa runs for 45
More than likely, it's the element. They begin to 'leak' small current as they get old and this will trip the GFCI
Posted on Jul 11, 2009
SOURCE: new MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
Posted on Jul 15, 2009
  • 5 Answers
SOURCE: i have a 37 lb thrust motor guide stealth 5forward
trolling motor parts.com
Posted on Apr 30, 2010
SOURCE: why is my 50 amp GFIC breaker tripping out? I have
There might be a few things here:
1) Big problem >> the #8 wire is a fire hazard connected to a 50Amp breaker
#8 is a 40 amp breaker
#6 is a 55 amp breaker
We put #6 on a 60 amp breaker
Are you saying you hooked the #8 wire to the new 50 amp breaker, and the hot tub called for #6 wire?
Upsize your wire and breaker to meet code
http://waterheatertimer.org/pdf/Wire-size-amp-rating.pdf
2) After putting the correct wire and breaker, you can still have a short in the circuit somewhere
We used to set equipment out in the field in early morning >> the grass was wet >> our equipment was fine, but the tiniest short would cause the GFCI to trip
I don't know where the problem is without a thorough checkout of every possible grounded surface. You need a good multi-meter
3) You better get an electrician over there to have a look before the place burns down or somebody wakes up dead in the hot water.
If I sound a bit scary here, it's because something doesn't sound right with your installation.
Posted on Oct 19, 2010
How to reset a cutler hammer HMCP E Breaker
Well, you should first - stand off to the side (not in front of any electrical panel, or device) when re-energizing a circuit breaker/switch, etc... Use your off hand, not your dominant hand when doing this. Reason is, if the breaker/switch blows up or out - and it happens to burn your hand (hopefully not...) - you will still have your good hand to work and get around with. Also, look away when doing this too - which will protect your eyes and face. This is why you DON'T stand in front of these electrical devices when turning them ON. Now, stand off to the side of this breaker/switch - look away, and using your less dominant hand - first turn the breaker/switch OFF (listen and feel for it to click in the OFF position)...then, turn the breaker/switch back ON. This should re-energize the breaker! If it trips again, then leave it in the TRIP position - and ask for further help. You'll need an experienced electrician to troubleshoot the problem. On this particular breaker - the two 40amp breakers are together, and the two 30amp breakers on the outside are together. When turning these OFF, and back ON...turn the two 40amp breakers OFF together, then back ON - and do the same to the two outside 30amp breakers as well. What you have here is what they call a Quad Breaker (4poles/circuits - which take up two spots in your electrical panel). So, you have a 2 pole/circuit...240 volt/40amp breaker - inside of a; 2 pole/circuit...240 volt/30amp breaker. This is most likely running a dryer and a range. Either way, SAFETY FIRST! I hope your problem is just a tripped circuit breaker! Also, make sure whatever you are trying to re-energize again - is ALL OFF!!! If your breaker trips again, disconnect ALL appliances involved - and then try it one more time! If it trips again, then call a licensed/certified electrician! Best of Luck to You...:)
Jul 13, 2014 | Cutler Hammer Bq Circuit Breaker Bq230240...
My motorguide trolling motor keeps tripping the 50 amp in line breaker every time I turn it on high speed. It is a 75 lb thrust digital tour model. When I take it out of the water and run it on high...
All motors will draw higher amperage with varying loads. Your hi speed motor winding has probably shorted some its winding's without having gone to ground. It probably needs to be replaced to get your hi speed back. I have run into similar problems in heavy commercial hydronic pumps. Best to have mechanic check it out. An OHM test with factory specs. will tell for sure.
Sep 04, 2013 | Electrical Supplies
Circuit breaker trips after water supply cycle
check the condensor fan in the compressor area and make sure its running if not the compressor will overheat causing high head pressures on the compressor causing it to draw too much current to operate the compressor and kick the breaker out,also make sure the condenser coils there are clean and it has ample air movement away from the wall
Apr 21, 2013 | Kitchen Appliances - Others
?-Is it ok to swap wires within fuse box if they amps on the breakers are the same? See details below... Ok, so I have a Sylvania fuse box. Both my A/C unit and my Range run off of thin, dual 40amp...
Yes it is OK, Your gfi's are real sensitive, anything can trip them off, a florescent light will trip them off. Anything not grounded in the circuit will cause it to trip. Take care of that later or don't use it. The 40 amps, I would just forget about the stove for now, get the ac going, cook in the microwave. But swapping the breaker is no big deal. Hope this helps.
Jul 17, 2010 | Sylvania Circuit Breaker - Zinsco/ RC 40...
New MotorGuide VariMAX trolling motor does not run
May 23, 2009 | MotorGuide Electrical Supplies
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
Electrical Supplies Logo
164 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
