Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
I have a Kenmore 106.56662500 side by side. The
I have a Kenmore 106.56662500 side by side. The ice maker is not filling at all. I pulled the ice-maker module out and checked for ice on the black rubber fill tube. It seemed clear. What else can I check? Should I check the connector for power? if so, how?
  • Tom Jun 23, 2009
    Where would the water valve be? I do get water from the door dispenser and the filter is new. I had read on some other posts about solinoid valves. Is this the same thing? Is there a way to test them
You will need to check your water valve on the fridge itself if it has a double valve. if it has a single valve and the water comes out of dispenser in the door then it is probably going to be the ice maker itself.
Posted on Jun 23, 2009
JSI-26 icemaker leaking water
You're ice maker is located on the left hand side of the freezer, if I'm correct.
Look to the back of the freezer slightly above the ice maker and you will see what they call the fill tube. Chances are ice has formed inside and when the ice maker goes to fill water sprays instead of flows out. In some models you can take the fill tube out from the back by removing two screws that hold it in, located at the upper right side if your behind it, and some you may have to pull out from inside.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 07, 2012 | Kenmore 21.9 cu. ft. Side-By-Side...
Kenmore Coldspot side by side ice maker not working, red lite bliking
Often I find your ice maker on the Kenmore side by side thefill tube frozen. The fill tube is ablack rubber hose located above and to the right of your ice maker. Simplypinch the tube to see if it frozen solid. If it is, use a hair dryer set onmedium to defrost the fill line. http://www.on-timeappliance.com/kenmorerefrigeratorrepairdallastx.html
Mar 24, 2012 | Kenmore Freezers
Making very little to no ice water filter has been changed out already
could have a bad water valve,next time send model number.on some of the ice makers you can pop off the white cover and on the right hand side you'll see to holes close together,you can jump out the ice maker to see if the water valve is sending up enough water to fill the ice maker,stick the end of the wire in each hole,you'll see the middle part start turning,when the theeth of the ice maker are at 9 oclock pull the wire out and watch to see the ice maker fill.if it doesn't fill and you hear the water valve turn on the valve is bad and has to be changed out.let me know how you make out
Jun 02, 2010 | Kenmore 53632 / 53634 Side by Side...
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Water not dispensing to fill up ice maker
Hi: Make sure your freezer is at zero degrees F. It will take 24-72hrs for an ice maker to produce when the freezer is at 0 degrees. Only then will the water fill the trays. I hope this helps, Jeff
Jul 07, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker will fill when there is still Ice in the tray
adjust the screw in the front of the ice maker under the plastic face pull on that there is a screw in there turn the screw till it is almost in and it should limt the problem
Dec 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Sep 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
497 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
