Question about Kitchen Ranges
Jenn-Air 30" slide in modular downdraft electric range completely stopped working. Household circuit breaker functioning, range is getting power, no apparent malfunction to power connection which is hard wired from wall(not plug into outlet), what is our next step?
    Master:
  • 697 Answers
Well, it's either all the burners are burnt, or power is not getting to the unit. You have to check where the power stops. Fuses/breakers on the unit? Bad switches? Loose wire?
Posted on May 13, 2014
alandc
  • 25 Answers
SOURCE: Don't know if the oven part of range is gas or electric
The model number can usually be found just inside the door or drawer (on the range itself).
All the Jenn-Air convection ovens I'm familiar with are electric even if the cook top is gas.
Posted on Jan 31, 2009
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
  • 10865 Answers
SOURCE: No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Posted on Jul 17, 2009
SOURCE: I have a jenn-air 30 inch downdraft electric slide
I have 30 inch slide in Jenn air and the black top is blistering and peeling. Jenn air replaced it one but the same thing is happening again. What can I replace this with.
Posted on Sep 22, 2009
protek480
  • 1714 Answers
SOURCE: My Jenn-Air SVE47100 slide in electric range does
Obviously it does not work fine. The thermostat sensor or the stat itself could be an issue. Can you see the sensor 'bulb'? Clean it with oven degreaser and steelwool. What is the temp in the oven with a 'oven thermometer'? Is this consistent with the oven readout?
Posted on Sep 24, 2009
Fan stopped working on Jennifer air downdraft electric cooktop. Elements still work fine. Circuit breaker did not trip. Took switch out of line by directly connecting fan leads. Still did not work when...
Generally there is a plug for the fan motor under the range, the panel where the drawer would be should lift off, you will then see the power to the fan motor. The fan motor is only 120Volts not 220V
always unplug electricity before attempting to repair on any electrical appliance
Aug 17, 2017 | Jenn-Air Cooktops
Oven doesn't heat up all the way on our Jenn-Air duel-fuel range
all repairs should be performed by an authorized service person. if your breakers were tripped there is a high voltage short or weak home breakers. when resetting the breakers make sure the dual breaker switches are in the on position. if the is ok check for the proper voltage is at the power outlet is correct.if it is ok unplug the range. be sure not to break the gas line. remove the rear panel check to see if the power cord power cord is secured to the power cord terminal.if the terminal is damaged do to the shortage at the terminal replace the terminal and power cord. when replacing the power cord and install the power cord restrain that usually comes with the.power cord.
Jun 02, 2017 | Jenn-Air JDS9860AAS Dual Fuel (Electric...
Heating element in my electric Jenn-air oven
This is one of the most simple repairs you can make on your range. And it's so affordable that you shouldn't think about replacing it!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we provide part removal/installation instructions for you when you purchase your parts through us.
We want to get you cooking again soon, so call us asap.
We look forward to working with you! Thanks, Ella
Jan 07, 2010 | Jenn-Air SVE47100 Slide-In Electric...
I have a jenn-air 30 inch downdraft electric slide in range jes 9800- I have lost the owners manual. How can I get a new one? The power was off for several hours and I need to reset the clock/day. thanks...
Jul 13, 2009 | Jenn-Air JES9800BA Electric Range
How do I get to the grease containers?
The grease container is at the bottom of the range. If you remove the front panel there is a little plastic cup that holds the grease. Hope this helps!!
Oct 10, 2008 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
60 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
