Question about Vehicle Parts & Accessories
Vw golf fsi 2l Fsi
I have a problem with starting the car the dash switches on but when I turn key to start nothing happens no cracking sound the dash just stays on & the key just turns. Is it a starter or alternator problem as the battery is fairly new
    Top Expert:
  • 3,698 Answers
Clean the battery cables. They may be making bad contact.
Starters usually do no go out all at once.
Posted on May 13, 2014
Air not blowing out dash vents
The evaporator coil is icing shut. Check the freon level and make sure there are no air leaks in the system.
May 02, 2013 | Vehicle Parts & Accessories
Need a digram for alternator belt on mk5 golf 1.6 fsi 04 reg thanks
The serpentine belt routing diagram on VW Golf mk5 1.6 FSi m.y. 2004
1. Without A/C (Air Conditioning)
2. With A/C (Air Conditioning)
AC = Air Conditioning (A/C)
CS = Crankshaft
G = Guide pulley
Gen = Generator (Alternator)
T = Tensioner
WP = Water Pump
Sep 20, 2011 | Volkswagen Golf Cars & Trucks
What is the cyl head torque setting for 05 vw golf 1.4 fsi 16v
Cylinder head instructions
Cylinder head torque setting for 2005 VW Golf 1.4 FSI
Renew bolts
Stage 1 = 30 Nm
Stage 2 = 90 degrees
Stage 3 = 90 degrees
Mar 23, 2011 | Volkswagen Golf Cars & Trucks
Vw golf se fsi 2006 30,000 miles. exhaust warning light on
If it is the 1.6 FSI model, it is very sensitive to the type of gasoline, it should be octane 97 or higher.
Very commonly, owners of this model use the 95 Octane gasoline, which seems to work ok, but the sensors in the exhaust (yellow motorwarning light) will eventually (can take a few years) clog up and you cant clean it or change the sensor easy either as you need to remove the whole exhaust system.
So either you let VW fix this for you (expensive) or you do it yourself (need a decent garage, equipment and a new sensor).
//kneron
Feb 26, 2011 | 2006 Volkswagen Golf
I own 07 plate golf 1.6 fsi 34k miles which
no KNOCKING sound is normal have oil pressure checked
Oct 27, 2009 | 2004 Volkswagen Golf
2006 golf 1.4 fsi-
Hi, just a random idea: are all the cables to the plugs okay? If there is no ignition, the problem could be there.
Oct 08, 2009 | 2006 Volkswagen Golf
I have a 55 plate VW Golf 2.0 Fsi - the alarm keeps going off by itself! We disconnected the battery last night (to get some sleep!) and it's started again today.... agh, HELP!
You probably have a faulty door,boot or bonnet lock.If you put the inside light switch to the setting for the light to come on when the doors are open,close all the doors and see if the light goes off.If your model golf has a display on the dash,it shuold tell you which door is open.It could also be a faulty interior sensor or a faulty alarm horn.A diagnostic machine will be able to tell you which was the last alarm activation.
Aug 29, 2009 | 2004 Volkswagen Golf
Hi. i have a 2004 2.0 gt fsi and it sounds like a diesel
the FSI engine is a direct injection engine and they can be noisy particulaly on idle ,if you have no other issues like warning lights lack of power and its always been like it then i sugest it is the nature of the beast .this is not ******** i am a vw master tech and have had many a conversation with customers about noisy FSI engines.hope this puts your mind at rest,alternativly go to VW dealer and get them to take a listen to confirm its normal.cheers
Apr 22, 2009 | 2004 Volkswagen Golf
Vehicle Parts & Accessories Logo
78 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
