Question about Toys
My syma x6 propeller keeps coming off ! How do fix it !
  • Ben Conner
    Ben Conner May 13, 2014
    My sym x6 quad copter propeller came off while reving up the motor ,but at a very low speed ,as I was just checking control function,as I had problem getting signal to respond for start up ,and the white propeller on starboard front side just flew off ! I have put the propeller back on and tightened the screw several times,and the same result prop comes off !Still low speed !I am at my wits end as to how to fix this problem ? Has anyone else had this problem ?
  • Ben Conner
    Ben Conner May 21, 2014
    I fixed it wih lock tite! !
How to unlock my nokia x6
You can get the unlock code for your Nokia X6 phone from any third party online vendors like SimpleUnlocking.com and unlock your phone from Network lock easily.
Oct 05, 2014 | Nokia X6 16GB Cell Phone
Hi my syma quadcopter x1 is stuck in the eversion how can i fix this ?? Thanks
What is the issue with the quadcopter?
All propellers spin but it flips over when trying to fly?
This would be clockwise and/or counter clockwise propellers on the wrong motor(s). For copters with an even number of propellers, each propeller turns the opposite direction from the ones on either side of it. The reason for this is so the combined engine torque is in equilibrium. Unbalancing this equilibrium is what allows the craft to turn left or right without a rudder or tail rotor.
Regardless of spin direction all propellers must blow air downwards.
Jun 22, 2014 | Syma rc x1 aerobatic bee quadcopter 2.4ghz...
SYMA RC CENTURY BOAT DOESN'T WORK OUTSIDE WATER
Actually the Syma Brand Boats are designed to not to work out of water. It is a safety feature. You can bypass that if you like. You remove each wire that is soldered to each propeller shaft and twist them together.
Apr 10, 2014 | SYMA Toys industrial 30" RC SYMA Century...
My Syma S107 bottom rotors won't turn. What is the fix?
Probably just the cog on the motor not meshing with the main shaft gear.
Kind regards, Julian
rccontrolfreak.co.uk
Aug 07, 2012 | SYMA Toys industrial New Syma S107 Radio...
How do I change the tail rotor on a syma s107
Carefully, while holding the silver metal motor in place, gently pull the rotor off of the rear drive shaft. Place new one on and push it gently into place. If it is loose, you can secure it with a VERY CAREFULLY applied mini-drop of super glue. Turn helicopter upside down and use as little glue as possible, keep it away from where the shaft meets the motor, and keep upside down until glue dries fully.
Hope this helps,
PvT
Jul 21, 2011 | SYMA Toys industrial New Syma S107 Mini...
Have a Syma S032 Heli. Is there a guide that shows how the chopter is constructed. My motor works intermediately and before I take apart to try to fix would be nice to have symatic to build back just in...
I just purchased one too and flew it for about 30minutes then the light went off, I put new batteries in and the light still won't come on. please help me :(
Sep 27, 2010 | SYMA Toys industrial Syma S032 Ready to...
Spinning syma s006 doesnt take off
the tail rotor keeps it from spinning thats its job
May 07, 2010 | SYMA Toys industrial Syma S006 Alloy Shark...
Spacer cone at propeller broke in half
Contact http://rcfishingworld.com they have parts for that boat It doesn't matter if you bought it from them or not, they are pretty cool about that sort of thing. You might also try searching on google, yahoo, or bing for the parts for model # ep-777
Jun 06, 2009 | SYMA Toys industrial 28" Blazingly Fast...
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
How to make itouch work with the zoom x6
you have to go to bottom right click the thiung that looks like a computer the y be a button that says fix
Dec 10, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
