Tronic tl999 Set the temp to 16 and after few minutes it increases to 26. Thanks
Why doesn't the fan on our comfort zone heater turn on when I turn on the power?
You need too hit the temp button increase temp then hit enter or set
Dec 01, 2014 | Comfort Zone Heating & Cooling
9.31 precor error 26 and loud noise
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if
Jan 25, 2014 | Dmm Vision Fitness T9500 Treadmill
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Precor 9.45 err 26
Model: All Models
Recommended Action:
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Feb 04, 2013 | Precor Exercise & Fitness
Precor Treadmill 9.21si Error Code 26, what does it mean
Model: All Models
Recommended Action:
Sep 07, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Speed error 26
Model: All Models
Recommended Action:
May 18, 2011 | Precor 923 LowImpact Treadmill
My HP a775c drops power after about 2 to 5 minutes. ... Then it won't power back up, even though the BLUE backlit Power Button is still on, ... I found that if I remove power from the machine for a...
it seems to be a power supply failure.
however, in the first few minutes it is working check (if available) the temp. reading in BIOS for the MB and/or CPU.
if the readings show rapidly increasing values, the cut-off may be just a protection kickin' in at a set threshold
Mar 02, 2011 | HP Pavilion a775c (A775CB) PC Desktop
I have a set of Desa propane logs that were installed about 16 years ago. They've always worked well, but this year, when I light them, they will only burn about a minute before turning themselves off. It...
I would replace the flame sensor. This is a metallic rod that is wired into controls that will shut gas valve off if it does not sense a temperature increase. Hope this helps you. Thanks
Dec 02, 2010 | Heating & Cooling
My siemens rev 16 hydronic will not heat even when the ignition light is on. it clicks on and it sounds like it has started but then stops a few minutes later.
Always look at the bottom of the screen at the 24 hr clock to see what time the thermostat is programmed to come on and off.You can then instantly see if your heater
should be on either T*& temp or TC temp. if the heating is not on when the time clock
indicates that it should check  to see that the time is set correctly.
Also check out the battery voltage.Is it  low or OK.
For Rev 16 manual.Click on the link mentioned below:--
http://www.google.co.in/#hl=en&q=siemens+rev+16+hydronic+&aq=f&aqi=&aql=&oq=&gs_rfai=&fp=f272b46d404fdcb9
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 22, 2010 | Heating & Cooling
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
