Question about Saeco XSmall Plus Automatic Espresso Machine
Coffee amount of saeco x small
How to increase the coffee amount of saeco x small. amount of coffee is too small. There is a programmer??
    Habit-Forming:
  • Saeco Expert
  • 147 Answers
No,don't have
Posted on Jun 09, 2014
  • 2039 Answers
SOURCE: Coffee to weak
if the ajustment of our coffee is griding the coffee to corsely not fine enought look in our manuel dont move the leveler of coofee unless the coffee is grinding in the waste basket our supposed to have like a little hockey puck fairly hard ajust it untill its like that let me now pierre merry christmas pierre
Posted on Dec 25, 2008
  • 1089 Answers
SOURCE: Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Posted on Jun 12, 2009
  • 80 Answers
SOURCE: no coffee comin out
zdravo,jesi li probao sa ciscenjem aparata,mozda masina trazi ciscenje sa specijalnom tecnoscu.naspi 0.75 l. tecnosti ili zavaraj masinu sa vodom otvori ventil pare i pritisni dugme za ciscenje i drzi nekoliko sekundi i onda bi trebalo da pocne sa ciscenjem,ovakav problem se obicno javlja kad masina treba ciscenje.
Posted on Aug 27, 2009
espressonist
  • 1711 Answers
SOURCE: saeco vienna leaks CLEAR water from under the machine.
The leaking is from the water pipe coming from the boiler thought the solenoid valve to coffee group. Their are many points that this leak can be so the only way to find it is to run the machine completly open without the plastic sides. The most posible postion is the plastic hose conected on the coffee group and some times you will have to place it back in position very easy.
Good luck.
Remeber to vote for this answer.
Posted on Feb 25, 2010
  • 1089 Answers
SOURCE: I have Saeco Vienna digital coffee machine already
Hi
You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
Posted on Mar 08, 2010
Saeco royal professional machine started giving half cup less coffee then normall
Do you know how to reset the amount of the cup amount. I have a different saeco model but this mite help. Press the button for a coffee and keep it pressed in this is how you reset the level on mine when you release the button it resets the level.
Nov 09, 2013 | Saeco Coffee Makers & Espresso Machines
I have a Saeco Royal Professional at work and when each of the three coffee size buttons are pressed you get three different sized coffees. I have just bought a new Saeco Royal professional for home and...
Hi
Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Apr 05, 2011 | Saeco Royal Professional Espresso Machine
When we push the option Large Coffee instead of giving us a large cup it gives us a small cup and strong. We push the small coffee and also get a small cup. What can we do to fix it?
HI
It needs to be reprogramed. If some one holds a coffee button down to long it will reset itself back to small coffee.
Jan 13, 2011 | Saeco Vienna Digital Coffee Maker,...
How do I increase the amount of coffee dispensed on the large cofee setting. At present the amount is small
Push and hold the button for the coffee you want, but hold it all the way through the process. Don’t release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
Sep 20, 2010 | Saeco Royal Professional Espresso Machine
Hi, I have a Saeco Incanto and both short & tall selections give the same very short coffee. It is very nice with crema but very very short. How can I increase the dosage? There doesn't seem to be a...
Hi
Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don’t release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn’t fix it, then you might need a new flow meter.
Aug 24, 2010 | Saeco Vienna SuperAutomatica Coffee...
Machine does not make enough coffee
There is a dial in front panel to controle water amount. Because one time brewing coffee powder amount is measured at the same colume, if dial is at the left side machine understands as to make very strong espresso and amont is only small, is center up side is mideum amont is a half of a cup, right side end is light coffe but enough amount for a coffee cup.
May 23, 2010 | Saeco Vienna De Luxe Espresso Machine
Saeco machine - only produces a small amount of coffee
Remove the brew unit and look at the top where the spout leaves the top piston(red oring) you will notice a small tube being held down with 2 screws, remove screws and carefully lift tube, and remove spring and white plastic ball(do not lose ball). Clean that chamber it will be blocked with coffee grounds. Re-assemble and try machine.
Jan 25, 2010 | Coffee Makers & Espresso Machines
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Flow
Check your grinder to see if the grinds may be too fine. Increase the grinder size and see if the coffee speed is increased.
If not, Contact saeco usa for support at 800-933-7876.
Out of warranty repairs can be completed by Cerini Coffee located in New York.
www.CeriniCoffee.com
Replacement parts for your saeco espresso machine located at http://cerinicoffee.com/Saeco_replacement_parts.asp.
Nov 23, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco XSmall Plus Automatic Espresso Machine Logo
141 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
