Question about Coffee Makers & Espresso Machines
How do you use choke on dewalt water blaster - Coffee Makers & Espresso Machines
    Top Expert:
  • 3,698 Answers
Www.dewalt.com/tool-categories/Pressure-Washers.aspx
See if you can find and download a manual from above.
Posted on May 13, 2014
Why does my Dewalt d55270 keep shutting off when I take it off choke?
The jets in the carburetor are restricted... remove bowl nut and clean out the carburetor use fine wire to wire out the jets and purge the old gas. Most have honda carbs and the jets are very fine holed and they are threaded into the base of the carb neck ...
Aug 30, 2014 | Dewalt D55270 Air Compressor 5.5Hp 8 Gal
Blaster stuck on full throttle
I would check the plastic heat isolator between the carb and cylinder head for leak.
Jul 07, 2013 | Yamaha 2004 Blaster Base
What is happening to my Dewalt DW421 spinning fast, but no random orbiting motion.
Probably need to replace bearing 6202. I took mine apart, dissambled the retainer and used PB Blaster on the bearing. It seems to be a short term fix. At least it's not operating at hyper speed anymore. Long term, I probably need to replace the bearing and maybe a new lower retainer if I can't press the bearing out.
May 25, 2013 | Dewalt DW421 5'' orbital sander
Dewalt d55270 will not keep running. carburetor is clean, it is in very good condition and has been maintained well since new.
Make sure that the choke is opening fully when warmed up.
Make sure that there is oil in the motor crankcase, I believe there is a low pressure switch in these models.
Shut off the fuel valve, open the reservoir and clean reservoir and check that float is not damaged or full of gasoline.
You could also try removing the belts to see if the motor will run without the compressor attached.
Nov 23, 2010 | Dewalt D55270 gas powered air compressors
Sand Blaster: air shot out of water trap.
1. do you have an adequate air compressor, meaning can deliver sufficient air supply to the sand blaster. 2. if you have an air leak at the water trap at the bottom of the trap it self. you need a new one. 3. it is a must to have a water trap when using a sand blaster.
So what I would do is replace the water trap and install the new water trap at the compressor between the compressor and the air hose coupling. the reason for this is your less likely to have it fail at the compressor VS at the sand blaster. once you have done that. you need to make sure that you have no more than 3/4 of media / sand in the sand blaster itself.
then open air supply valve #1 where the water trap is or was a 1/4 -1/2 way. then open the mid way valve#2 1/4 - 3/4 way. and the bottom valve#3 open 1/4 - 3/4 way. getting the air supply valves all set correctly is hard to do some times.
Air valve #1 supplys the air to the blaster.( more air the better)
Air valve #2 supplys the air going into the top of the blaster tank. ( wich pressurizes the top of the tank to push the sand or media downward )
Air valve #3 supplys the air mixture to sand at the bottom of the tank.
Mar 20, 2017 | Clarke Power Products Clarke SB9008 10...
1993 blaster wont stay running
try cleaning carb and see if the choke is hung up also make sure it has the right plug ngk b8es
Feb 22, 2009 | 2003 Yamaha YZ 250
Titanium plus stuck on rinsing cyle
go in the menu remove rince cycle after it say ventilate put water in container start machine open valve it should ventilate if it doesnt remove water container take turkey blaster put water in it put the blaster in the hole were the water container goes force pressure with the blaster at the same time open valve you vented by now put cointainer back fill with water enjoy thanks for using fixya pierre
Feb 10, 2008 | Gaggia Titanium Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
