Cooltech 700 display reads high tank weight resetting but machine does nothing else
    President:
  • 180 Answers
Please do the following:1# With main power OFF,disconnect liquid line from ISV (internal tank) & press tank valve to reduce refrigerant manually as needed.2# Disconnect air purge line & reduce access air from ISV as needed.3# Turn main power ON & calibrate scal if needed.Hope this will solve your problem.
Posted on Jun 25, 2009
The high pressure unit is disabled in my Robinair Cooltech 34700z wat could be the problem?
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem, if so please vot for it
Jan 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
Robinair cooltech 34788 scale error reset
You may overfill the ISV tank. #1 Open front cover & close LIQUID valve on the ISV. #2 Disconnect LIQUID hose from tank,then open tank liquid valve (which you close earlier) to reduce some refrigerant manually from the ISV tank. #3 after reduce refrigerant from tank, re-connect everything & switch on the machine. #4 If you still have the same problem then you have to re-calibrate the scal. I hope this will help you
Nov 04, 2010 | Robinair Cool Tech 34700Z Recovery,...
AT MACHINE TURN ON DISPLAYS UNDER HIGH PRESSURE AND DISPLAY SAYS TO RESET WITH MAIN MENU BUTTON.BUT WILL NOT RESET
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just check the following :- 1# Verify the ISV tank is not overfilled.if full,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid & High pressure switch for proper operation.Hope this will solve your problem, Best of luck & vote for my solution!
Jul 12, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi. We've got a CoolTech 34788. Whenever the machine tries to purge air from the tank, we are consistently getting a message saying that the "Air purge timed out". The internal tank shows ~10 lbs of r134a....
It's sound like normal. However when thes message come again you just press Stop/No key to terminates this function. Press Recover & see if the machine is going to recovery after self clearing. If it is then you can continue to work. Hope this will help you best of luck!
Jul 01, 2010 | Robinair Cool Tech 34700Z Recovery,...
The display shows 13.20 lb but the tank is empty and will not fill.
The display MAY be showing the TARE weight of the tank which would probably be near the 13Lb you are reading. There may be a reset for this to zero it. I have a different unit so I can only point out possibilities.
I would carefully read the proceedure to make sure all steps you are using are correct... If a connection is not quite right that might be blocking the recovery.
Jun 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
Nothing will display on the read out
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
Wont clear filter
If the clearing the filter screen will not go off then it is sure that compressor is not good.please check the compressor with vacuum gauge & make sure is has 13" HG of suction.
Aug 12, 2009 | Robinair Cool Tech 34700Z Recovery,...
Source tank empty
You have to rebuild tank fill solenoid.Thank you.
Mar 26, 2009 | Robinair Cool Tech 34700Z Recovery,...
Heating & Cooling Logo
190 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
