Question about Woods Outdoor Lighting Timer
I have a first alert 2 outlet timer how do i set it.
How do i set it .
  • Woods Master
  • 5,245 Answers
Copy following links to help identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
First Alert usually repackages cheap versions of other brands, but programming is same.
Gene
Posted on May 13, 2014
I was wondering if the dual outlets can be program individually? For example, both start a 6am but one end at 8pm and the other one at 10pm. Thanks
No. Woods does not make 2-channel timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#digital
Nor is this feature available through Intermatic wall timers, GE wall timers, Leviton, Swilight, UPM, Tork, Westinghouse, Westek, Utilitec, maplin, Stanley, Brinks, Timex, Kichler, Hagar, First Alert, sylvania, Aube, Honeywell, coleman, HPM, etc etc.
However, you can buy narrow timers like Westek TE22, also similar sold by Brinks... and 2 different timers can plug into same duplex outlet... letting you control 2 different loads from same outlet... by using two timers: usually this type timer is sold as 2-pack
http://waterheatertimer.org/Woods-timers-and-manuals.html#Westek
There are also box timers, like Intermatic ET series, that can be programmed for 2-channel operation where same timer controls two different loads, each with different weekly or daily schedule ... Intermatic PE153 offers 3-chanels, and there is one timer, ET90000 that can be programmed for 40+ channels with 4000 set points and 365 day calendar for each channel etc
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
Tork also offers multi-channel box timers.
Gene.
Aug 04, 2013 | Woods Hardware & Accessories
The "F" LED remains on and I'm unable to get it to change states by depressing the settings button. This has happened on two of the units that are both less than 6 months old. Any ideas?
Copy following link to identify timer, and find comparable product that might last longer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
Check output voltage at outlet using multimeter. Should be minimum 80% rated value or 110Volt outlet = 88 volts
Check outlet with circuit analyzer for correct polarity and grounding.
All timers come with 1 year limited warranty, in this case it will be through seller because first alert does not show timers on their website.
Don't buy First Alert products.
They are generally cheaply made promotional grade timers.
I recommend Intermatic HB61RC or Woods 49103 or Intermatic HB65R because their products are good, and warranty policy is direct from company.
Oct 24, 2012 | First Alert Hardware & Accessories
Directions for first alert timer model 24T2
First alert 24-hour analog timer has segments located around the dial.
These segments are lifted using a finger.
Copy following link to see how to set analog timers by experimenting with features;
Jul 20, 2012 | First Alert 24 Hour Timers - 2 For The...
How do i set this time to come on and go off daily
I believe the First Alert timer is same as GE 15151 vacation timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#vacation
If this is not your timer, then add a comment.
Also look at Woods timers on link below to help identify timer.
A vacation timer turns on-and-off randomly to give the appearance that somebody is home
This timer cannot be set for daily on-off schedule.
GE markets a number of timers for daily repeat programming:
When buying a timer, note that some are for 2-prong plugs and some for 3-prong plugs
http://www.amazon.com/dp/B0015GKI96/?tag=picc-20
http://www.amazon.com/dp/B002HEY300/?tag=picc-20
Woods makes daily timers and a weekly timer
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
http://www.amazon.com/Woods-59202-Vacation-Security-Appliance/dp/B001Q9EFT6
Dec 20, 2010 | First Alert Tm261 7Day Vacation Timer
How do i set this timer to come on and go off daily?
A vacation timer turns on-and-off randomly to give the appearance that somebody is home.
How does this timer work? I lost pkg with info.
Rotate dial until current day and time line up with arrowhead located on inner dial.
The timer will turn on-off according to preset schedule
Dec 19, 2010 | First Alert Tm261 7Day Vacation Timer
I bought two First Alert 24 hour timer with clock units some time in the past, but never opened them for use. Now I have opened one of them and the inner pieces are all scattered inside of the unit. The...
First Alert timers have prefix numbers and look similar to Woods promotional timers.
Searching First Alert site turns up no timers, which makes me think they have a timer packaged for them. Why they select promotional timers probably reflects need for retail price point. Searching for your model number turns up no on-line sellers, but does turn up fixya problems about First Alert timers ... which may be why you're here on promise of manuals and repairs.
http://www.firstalert.com/
Woods makes a top-line 2-pack 24-hour timer that sells on Amazon:
These timers have 2-prong outlet, and they will NOT fall apart.
Amazon sells single-pack timers with 3-prong outlet: for 24-hour and 7-day
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
That being said, I've tested these timers.
Except for some brands of box-type timers, timers today are one-piece apparatus that have no repair parts. Bust it and throw it away.
Plug-in wall timers are not supposed to fall apart, or even come apart.
It sounds like first timer out of package is defective.
Sorry for the loss, and frankly I am going to contact First Alert and ask why they don't support their timer customers with manuals and information.
Nov 29, 2010 | First Alert 24 Hour Timers - 2 For The...
Woods Outdoor Lighting Timer Logo
94 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
jdthefixer
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
