Question about Compaq Armada M700 Notebook
Armada m700 no post
Hi, this m700 (I got it in the current state).
No battery, keyboard & no drives attached, so the problem is in inner parts.
When I take off the screen it turns on (fan is spinning, 3 right leds on) but no post, no image on external monitor. When I put it's lcd back on, I get orange led blinking by the battery indicator, but no post as well.
Any ideas? Yes, I've replaced the ac card, the adapter is new, working with another laptop just fine.
  • ganjubas Nov 04, 2007
    Hi again,
    ok, I have 3 replacement screens, none of them is working with this specific laptop, but they work perfectly on other m700.
    I get NO POST, therefore I cannot clear up/default my bios.
    I added some ram, now, if I just plug in the ac cord it tries to post, but fails in about 3-4 seconds and repeats itself , if I plug the cord while holding the power button it turns the screen white and still no post.
  • 69 Answers
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Display issue. . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
To isolate and to resolve the issue please try below solutions....
***NOTE** Before starting below solutions I recommend you to RESEAT RAM in your PC, since it might help in resolving issue. Mostly issue related to display could cause of bad RAM.
Solution 1:
Please Restart your notebook and then use the Flash light( Torch light) to check if you can see any image on screen . If no image is seen , then it could be issue with Display screen or an issue with Operating System.
To confirm the issue, please once again restart the PC and then tap F10 key to boot the PC in to BIOS. Now, please check the issue even in BIOS, use same Flash light to check if there is any visible characters in BIOS.
if you are able to see characters in BIOS, then it confirms that is an fault with OS,,, then go ahead try BIOS Update, BIOS default... if the issue still persists use the recovery disk and reinstall the OPERATING SYSTEM in your PC.
If you do not see any Characters in BIOS, then it confirms that it is an fault with NB,(Notebook) please contact HP on this issue for SERVICE OF NB.(,(Notebook)
Press F9 while in BIOS and then once again press F10 . and then save/exit from BIOS
Please open below link in the new Internet Explorer. Copy and Paste the link at the address bar and then click GO. This will open a web page that titles as "Download drivers and software "
Link :
Once if you open web page, please select the Operating system that you are using, this will open a new web page. Now, click on BIOS option , If there is any BIOS update try to download it else. do not download.
This should resolve the issue for you.
If you need any further assistance on the issue, you can mail me at . I'll be glad to help you.
Posted on Nov 04, 2007
How to detect sata hard drive P4M800-M7 Motherboard the sata hard drive can't detect
Hi fleetpio,
1. How to detect sata HD?- I am assuming that you have fixed the hardware part. During POST (Power On Self Test) press delete key inyour keyboard.
2. After pressing delete, a menu like the image above will appear. use arrow key to navigate, enter to select, +/- to modify values, Esc to exit current menu and F10 to save settings. proceed to Features Setup and press enter.
3. Another menu will appear like the image shown above, on the Onboard SATA-IDE from IDE change it to SATA-IDE.
4. Press F10, Saves the current configuration and exit setup.
5. To verify if the SATA hard drive has been detected, look on your POST if the HD appears. If the full screen logo appears repeat Step1 proceed to Standard CMOS Setup, check if youre HD appears.
Hopefully this information helps.
Thank you for using FixYa.
Sep 01, 2011 | EliteGroup P4M800-M7 Motherboard
Need to replace the keyboard of your DELL laptop? It is not as difficult as it...
Need to replace the keyboard of your DELL laptop? It is not as difficult as it sounds; it should take no more than 20 minutes. Also, a DELL laptop OEM keyboard replacement is usually around $20-$40, which is much less than what a computer repair shop would charge you for the repair. Here is what you need to do:
1) KEYBOARD PART NUMBER: Be sure you have the right keyboard for your laptop. The easiest way to do this is to look up in your user's manual for the PART NUMBER for your laptop's keyboard. If this is not an option, there are other ways to get the right part. The most direct one is to just remove the keyboard and look up the part on the keyboard itself (since you'll need to remove it anyways to replace it).
2) REMOVE THE KEYBOARD: Removing the keyboard depends on the specific model you have, but in general in involves the following steps:
a) Unplug the AC charger
b) Remove the battery from the laptop
c) There should be a small WHITE button located on the top right of the keyboard, right on the edge of the keyboard. Using a screwdriver, press it in and lift the flat piece of plastic that goes from the right to the left, just on top of the keyboard. BE CAREFUL NOT TO BREAK IT.
d) Now you should see 2 or more screws (usually Phillips screws) holding the keyboard down. Remove them.
e) Carefully lift the keyboard FROM THE TOP SIDE and SLIDE IT OUT about 2 inches (5 cm). The keyboard is attached to the laptop with a flat cable, so be careful.
f) Unplug the flat cable from the keyboard and remove the old keyboard
g) Get the new keyboard and plug in the flat cable to the laptop
h) Slide the keyboard in, bottom part first (the bottom part of the keyboard is the one FURTHEST from the screen). Press the keyboard down in its place.
i) Re-attach the 2 screws you removed in step (d). Be careful NOT to over-tighten the screws or you may damage the new keyboard.
j) Re-attach the flat plastic part on top of the keyboard, starting from the LEFT and making your way to the RIGHT, carefully pressing it down in place.
k) Re-install the battery and the AC charger. Turn on the laptop.
You can find a video of the whole installation process here:
You can find laptop replacement parts (including keyboards, screens and rechargeable batteries) on Ebay or on (the latter also has a nice search feature, to locate the right replacement part)
on Mar 28, 2010 | Computers & Internet
My new hp keyboard types " character where @ is and @ where " is. How can this be fixed?
Your new keyboard is set up for the United Kingdom which has those keys switched. Go to the control panel > Regional and Language > Go through all these settings and tabs and make sure all the settings are set to the "United States-English", Go to the Ketboards and languages tab > when the window comes up, make sure that the top box states United States-US and below make sure that the keyboard is US, if there is another keyboard, like can remove that one. Now go through the rest of the tabs and make sure they are all changed or listed as United States. Reboot to set.
Jun 18, 2010 | HP P2360AA Keyboard/Mouse
Bios Issue/Hard Drive Upgrade
i have installed a 60gb hdd into an m700 without even having to stuff with the bios...
Xp sp2 allows you to install larger drives then the bios reccomends.
Feb 18, 2009 | Compaq Armada M700 Notebook
Keyboard not work
Hello ,
As per what i understand from the issue you stated it has the possible solutions :
1. perform a Power Drain Test to drain out the accumulated static charge from within the notebook (happens with every laptop) - let the laptop be on , remove the power cord , remove the battery directly without directly shutting the laptop. The laptop will shut down once you remove the battery. Then press and hold the power button for the next 50 seconds continuously. Then attach the battery , then the power cord and power on the notebook. Check the keyboard . If no go , then
2. use an external keyboard . Attach the external keyboard to the laptop and boot into the normal OS desktop. Open Device Manager and check if there are any conflicts. Or else directly update/flash the BIOS by clicking on the link below :
If unable to do so , please mail back giving the Serial Number of the laptop and the Product Number (loacted underneath the laptop on a white label beginning with s/n and p/n respectively ) and i shall send you the exact BIOS update/flash link .
Regards ,
Aug 02, 2008 | HP Compaq Presario 2200 Notebook
Compaq Armada M700, Dim Screen
There is a dimmer function that is part of the keyboard on most notebooks. You use the Fn key and some other key (Mine is F1 and F1) Look for what looks like Sun in blue print on the key. You should find 2 of them. One will be the brightness up and the other brightness down. You can try those.
More likely, something has come loose internally.
1. It could be the backlight for the screen is broken or a connection loose. You should be able to see the light when you look at the side of the display.
2. The AC power connector may have been broken and the notebook is only on battery power. By default most systems are dimmer when on battery power. Check to see if your charge indicator light is on. If not, that may be the problem.
I hope this helps.
May 07, 2008 | Compaq Armada M700 Notebook
Blank screen
hi friend
here is link for u 24 hour online service tecnision 4u
contect him diis cribe ur hole the problem he will gave u a solution
here is link for u
Mar 31, 2008 | Compaq Armada M700 Notebook
Compaq armada m700 mouse is very irratic
did you try replacing the mouse? Or installed the mouse driver.
Jan 09, 2008 | Compaq Armada M700 Notebook
Logitech M700 Mouse recharging problem
try replacing batteries by newones,since they are ni-cd type,they do have limited no.of charge/recharge cycles and tend to lose performance with time.
Jan 08, 2008 | Logitech Cordless Mouse
Power up password
It could be under the keyboard or under the hard disc drive, there may be peice if tape over it to secure it. it looks like a large flat 3v watch battery.
Feb 12, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
294 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
