York inverter r410a ls - Heating & Cooling
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
How much r410a need for goodman air conditioners
data plate on side of outside unit gives you the amount. 410a is a blend & you have to charge with a inverted bottle.
Jun 14, 2014 | Goodman Heating & Cooling
Electrolux r410a inverter
Low freon pressure is common. Could be a bad air sensor. Call the factory, put your actor on and ask support ;)
Sep 24, 2013 | Heating & Cooling
I have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Dec 29, 2009 | York Exercise & Fitness
How to clean outside unit aiwell r410a dc inverter
kill all power and clean with water hose
Oct 27, 2009 | Heating & Cooling
York t101 treadmill ls error
York treadmill T101 will not run has a error L5
May 11, 2009 | York Exercise & Fitness
Ls error
Showing l5 or ls on sceen of my york t101 treadmill please help me out thanks.
May 09, 2009 | Exercise & Fitness
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
