Question about Microsoft Flight Simulator X for Windows
Fix error 1311 - Microsoft Flight Simulator X for Windows
Why cant i use Office or word & when i try to reinstall or fix it ?
Somtetimes happens. If your copy is legal, ask your provider
Aug 01, 2014 | Microsoft Office 2010
Error 1311
have you tried turning the printer off and taking the usb lead out
Apr 23, 2014 | Epson Computers & Internet
When i installing adobe photoshop cs2 , there is error 1311 so how can i solve this
Your CD might be damaged in someway.
You can try this to solve it.
1. Copy the content from the CD over to you computer.
2. Run the setup you just copied to your computer. (if you have Windows 7 or Windows Vista you will have to run the setup as administrator.)
That should fix your problem.
Mar 07, 2011 | Adobe Photoshop CS2 for PC
Simple, step-by-step instructions on how to fix Error 1311 in Windows XP -- this error popped up when trying to repair/fix original installation of Microsoft Office 2003 -- not very computer savvy, but can...
Hello
Thank you for using
FixYa for your problem
To resolve this problem, copy the contents of the Office CD to a folder on your hard disk, and then run Office Setup from this folder. To do this, follow these steps:
  1. On your desktop, double-click My Computer.
  2. Double-click the local on which you want to create a new folder.
  3. On the File menu, point to New, and then click Folder.
  4. Type a name for the new folder, and then press ENTER. For example, type OfficeXPCD.
  5. Insert the Office CD into your CD-ROM or DVD-ROM drive. Hold down SHIFT as you insert the CD to prevent Setup from starting automatically.
  6. In My Computer, right-click the CD-ROM or DVD-ROM drive, and then click Explore.
  7. On the Edit menu, click Select All.
  8. On the Edit menu, click Copy.
  9. Right-click the folder that you created in step 3, and then click Paste.
  10. When all the files have been copied to the new folder, quit all other programs that are running, and then double-click Setup.exe in the folder that you created in step 3 to start Windows Installer and Office Setup.
  11. Follow the on-screen instructions to complete the Office installation.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Microsoft Windows XP Home Edition
Error code 0x886a789a on my 7410 All In One Printer. What is the fix???
This is common error on this model. This would cost you more than 200 bucks, if you call HP. If you wish, call and check right now. However, you could also fix it yourself. Follow the below guide :-
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
This is the best guide i have ever seen for this error. More likely, you would be able to fix and save money.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | HP PSC 1311 All-In-One InkJet Printer
Error 1311 on window vista
try the websites piratebay.com,brothersoft.com,soft82.com,toggle.com or adobe.com if these didnt worked u have to buy the cd or u have buy it online
Oct 07, 2009 | Adobe Photoshop CS2 for PC
Unable to install adobereader8.1.2 Error 1311 Install does not progress to completion. reflects error 1311
1. Choose Start > Run.
2. Type regedit in the Open box, and then click OK to start the Windows Registry Editor.
3. Navigate to the following two registry keys:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.svg
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.svgz
4. Right-click on each key and set the rights for the SYSTEM account to Full.
rahul
Feb 22, 2009 | Microsoft Windows XP Professional
Installation failure.Error 1311: Source not found.Verify file exi
http://support.microsoft.com/default.aspx/kb/325076
i hope this helps basicly it sais you might not have enough rights.
there is also a solution in there.
i couldnt find anything else on the error you specified.
Feb 07, 2009 | Microsoft Office Home and Student 2007...
Microsoft Flight Simulator X for Windows Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
