Question about WYSE R90L7 Thin Client - Sempron 1.50 GHz (90954401L) Network Terminal
How reset factory
How to reset client to the factory defaults
2 Suggested Answers
dontrunrock
  • 36 Answers
SOURCE: How to reset to factory default on a WYSE thin client 1125se
The simplest and most often used method is using Wyse Simple Imager in a PXE setting. This is how most large enterprises deploy images to Wyse terminals.
If this is not an option, there are some other options available. Please refer to this website for some home-brew solutions:
http://www.freewysemonkeys.com/modules.php?name=News&file=article&sid=55
Posted on Oct 21, 2012
Deracam will not reset. How do I get it to reset?
If you want to reset your IP Camera to factory defaults, you can use the following 3 methods. After resetting the device you will lose all your settings except Client Settings.
Method 1:Hard reset/ By pressing the RESET button
Step 1- Keep the device powered on for at least 30 seconds to complete its normal startup.
Step 2- Find something like a pin to press the Reset button on the camera and hold it for 15 seconds to restore the settings to factory defaults.
Step 3- Afterwards release Reset button, and the camera will be restored to factory defaults after rebooting.
Note: Reboot process takes about 1 min, please be patient.
Method 2:By using Intelligent IP Installer
Step 1- Install the Intelligent IP Installer with the CD.
Step 2- Run the Intelligent IP Installer. Click Search to find your device.
Step 3- Select your Camera in UPnP device list, click Factory default on the right side.
Step 4- Type the username and password in the login page, the default username and password are both admin. Wait for the device to reboot.
If you changed the username and password before and forgot the username and password, you have to follow
Method 1, make a hard reset.
Method 3:By using Web-based Utility (management page)
Step 1- Open the web browser and type the IP address of the IP Camera into the address bar, press Enter. If you have changed the default port number is 80, Then type the IP address of the camera: new port number into the address bar of web browser.
Step 2- Type the username and password in the login page, the default username and password are both admin. Then click OK to connect to the device.
Step 3- Click SETTING -> BASIC -> Initialize on the left side, and then click Factory default to reset this IP Camera to the factory default settings.
Step 4- Keep waiting until the progress bar shows completion.
Feb 04, 2018 | Miscellaneous
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Factory reset
Chapter15 The Init Button
The Init button is used for maintenance: Simultaneously press Init button and turn on (by plugging
in the power adaptor) the Server until USB1 LED indicator simultaneously blinks. After that, the
Server will do the following tasks:
A. Perform a Factory Default of the MFP server, which will restore most of the parameters and
settings to factory default values,
B. Perform a TFTP server. You can upgrade new firmware using any TFTP client tool.
Note: After performing the tasks mentioned above, you have to unplug the power adaptor and then
plug in the power adaptor to restart the Server.
HMPS1U Print Server for Multifunction Printers
Mar 10, 2014 | Hawking (HMPS1U) (DHHMPS1U) Print Server
I set my resolution too high on my VXL Itona C42 thinclient. Now i'm stuck with no display. how do i get it back to normal?
To Reset the display to 640 x 480 press :- CTRL+ALT+SHIFT+F5
To reset the terminal to factory defaults press :- CTRL+ALT+SHIFT+F9
itona, vxl, reset, factory defaults, screen resolution, display
Feb 14, 2012 | Vixel VXL Itona TC2341CE Thin Client ...
Is there a reset button to reset the c10le terminal to factory defaults
No. A factory reset can be done by either pressing and holding the G key or continually tapping the G key.
Mar 04, 2011 | WYSE C10LE Thin Client (90217501L) Network...
How can I reset chip samsung scx 4200 all in one laser printer. kumar
I am presuming you want to reset all the systems settings to the factory defaults. Try this:
Clearing memory
You can selectively clear information stored in your machine's memory.
1 Press Menu until Maintenance appears on the top line of the display.
2 Press the scroll button ( or ) until Clear Settings appears and press OK.
3 Press the scroll button ( or ) to select the item you want to clear.
• Paper Setting: Resets all of the Paper Setting options to the factory default.
• Copy Setup: Resets all of the Copy Setup options to the factory default.
• All Settings: Resets all of your settings to the factory default.
• Machine Setup: Resets all of the system settings, such as the display language and save
mode, to the factory default.
4 Press OK to confirm clearing. The selected setting is cleared.
5 Repeat steps 3 through 4 to clear another setting.
6 Press Stop/Clear to return to Standby mode.
Nov 30, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Picked up a Compex NetPassage 27G at a yard sale and cant access it. Does it have a default username and password?
Hi
start by trying these:
Default IP for all Compex's Routers/ APs/ Client Adapters: 192.168.168.1 Default IP for all Compex's Modems: 192.168.1.1 Default IP for all Compex's Switches: 192.168.100.128 Default Password for all Compex's products: Password Default User ID for Compex's modem: Admin
alternatively most router will have a reset button that's usually behind a little hole in the back or at the bottom of the unit. inspect the device carefully and introduce something sharp (that won't break) through that hole while the unit is powered and press for 30 to 60 seconds, this is usually how devices are brought back to factory defaults. if this does not work it's like the device is defective and you may want to get your money back!
hope that helps!
Apr 19, 2010 | Compex NetPassage 27G Wireless Router...
I have incoming connection, but WLAN from ports doesn't have internet.
There should be a reset button on the back of the device that will allow you to reset it to "Factory Default".
You will have to reconfigure the router for security once this is done.
If the router does not reset to factory, then I would replace the router all together. I had to do that for a client this morning.
Good luck
-Carlos:
Jan 07, 2010 | D-Link DI-624M Router (DI624MRE)
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
Hardware reset
Double-clicking the System icon in the Control Panel opens the System Info dialog box.You can use this dialog box to allocate thin client memory and reset the thin client to factory defaults.
The General tab contains a check box that allows you to reset the thin client to factory defaults (the check box is active for administrators only).
You can reset the thin client to factory default settings by selecting the *Reset the terminal to factory-default property settings* check box (the System Settings Change message displays and you can confirm and follow the instructions provided to reset the thin client).
Mar 01, 2007 | WYSE Winterm S30 Network Terminal
WYSE R90L7 Thin Client - Sempron 1.50 GHz (90954401L) Network Terminal Logo
90 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
