How to photocopy on a canon pixma mg3250
What buttons do I press to photocopy
5 Suggested Answers
SOURCE: canon pixma mp220
I had the same problem, and this is the fix.
1. Go to Canon's website and find the "Drivers and Downloads" section. From there, you will need to specify the subcategories of your hardware, and then your specific model (for example: Hybrid (i.e.-Printer & Scanner), Inkjet, MP470 Series)
2. When you find the proper page for your model printer, select your operating system from the drop down list.
3. Scroll down the page. You will see all versions of the drivers and programs to download. Download the latest version of the driver. You should also download the "My Printer" program. This is useful for troubleshooting and maintenance.
4. Keep scrolling until you find the "MP Navigator" program. This is a very important program, and is necessary for the scanner to operate properly. Download this program.
5. One MP Navigator is downloaded, verify that the scanner will use this program when it operates. To do this, go to the Start menu, click on Control Panel, click on Scanners and Cameras, click the printer that you will be using, then click properties. Click the tab at the top that says "Events." You will then see a drop down menu with the options Save to PC, Save as PDF, etc. Verify for each option that your computer is either opening the MP Navigator program, or that the computer will prompt you on which program to open.
This should get your scanner working. Hope this helps!
Posted on Sep 15, 2009
komguy
  • 2306 Answers
SOURCE: Canon Pixma IP2000 - mains fuse blows
Try removing the printhead before powering up, after that you need either a new power supply or main logic pcb.
Posted on Nov 25, 2009
Testimonial: "Thanks - I'll try that"
  • 73 Answers
SOURCE: Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Posted on Dec 07, 2009
pineworks
  • 4041 Answers
SOURCE: Cant print using Canon Pixma MX300
Hi
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Or try this
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
  1. Switch off the Canon MX300 and disconnect the power cable.
  2. While press and hold the power button, Connect the power cable to electric socket.
  3. While pressing the power button, press the “Cancel/Stop” button (red button).
  4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
  5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
  6. A test page will print.
  7. Open the cover, like you are about to change the cartridges.
  8. Disconnect the power cable again without switch off the printer.
  9. Take out the both cartridges.
  10. Close the cover.
  11. Connect the power cable and turn on the printer.
  12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Hi, Can I scan and print by pressing buttons on machine.
yes, you can, have go to this site and download the manual, all is explained step by step.:
https://www.canon.co.uk/printers/inkjet/pixma/pixma_mg3250/
select first brochure - all explained in short and then go to downloads and download full manual.
hope this will help you - do not forget to vote...
Mar 24, 2015 | Canon PIXMA MG3250 All-in-One Inkjet...
Got a canon pixma mg3250 wireless printer set it up as told put in cd rom seemed to have done everything i was supposed to but it wont print
A wifi printer needs to connect to your wifi network and it needs to be recognized by Windows.If your wifi network is already set up and working with other devices (tablets, smartphones, etc) , then you may be dealing with a simple security issue ( you may need to enter the proper passphrase, network key, etc.when you set up the printer) . If you do not have a wireless network already set up, then things get very complicated!!!
Feb 28, 2015 | Canon PIXMA MG3250 All-in-One Inkjet...
HOW DO I PRINT ON TWO SIDES?WITH MG3250
Not sure if MG3250 has 2 sided printing option, but if it does, there is a tick box with 'Duplex printing' next to it in 'Printer properties' on 'Quick setup' page. Tick the box!
Feb 27, 2015 | Canon PIXMA MG3250 All-in-One Inkjet...
How do I change the ink cartridge canon pixmar mg3250
Hi
If you go here :- Canon PIXMA MG3250 you can download the first manual on the list. If you then double click the file, the manual for this printer will be installed to your desktop as an icon labelled "Canon MG3200 series On-screen Manual".
If you open this you will be able to access detailed instructions for the machines functions. If you search for "cartridge" then you will get detailed instructions on how to change a cartridge.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 11, 2015 | Canon Office Equipment & Supplies
My Cannon MG3250 won't print, it show E17 then E20. It makes a grinding noise as if the gear cogs are slipping. Can I fix it?
This could be a number of things, but most likely a part has failed & unfortunately not something that can be diagnosed without seeing the device.
Aug 24, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
Why is canon pixmas mg3250 b and c lights flashing
What does the amber button marked b mean on my canon pixma printer mean
Jul 11, 2014 | Office Equipment & Supplies
I have lost my installation disk for my canon mg3250
I lost the disk to my canon mg3250 and need to re-install on my PC as I wiped everything. I tried downloading from the site but it my PC says it doesn't recognise the software even though I have put the correct operating system choice in?
Apr 06, 2013 | Canon PIXMA Office Equipment & Supplies
How do i photocopy ?
Put paper under scanner door, and hit Copy
Mar 13, 2011 | Canon PIXMA MP130 All-In-One InkJet...
It just won't scan. It prints fine and it photocopies fine but if I go on to scan and choose any of the scanning options it says "Place document on platen glass and press ()" (i tried to draw the button...
Hey Yasmin,
I had the same problem.
I installed the MP Navigator (MP Navigator Ver. 3.03 (Windows 7/7 x64/Vista/Vista64/XP/XP x64/2000/Me/98) from the canon website (http://support-au.canon.com.au/contents/AU/EN/0900173112.html) and then I released the scannerlock (http://www.fixya.com/support/t5363070-trace_release_scanner_lock)
and then I could scan! Not only through the printer itself by pressing the (<I>) button but also through the MP Navigator program. When I pressed the (<I>) button on the printer, the scanned document would be automatically saved on the computer in a folder of MP Navigator.
Hope this helps you!
Esther
Jul 13, 2010 | Canon PIXMA MP810 All-In-One InkJet...
32 people viewed this question
k24674
jasbo
jasbo
